avatar_Gondor
The REAL Wessex HC.2 Protatype
Started by Gondor, July 11, 2020, 02:29:24 PM
Well the title says it all really.
Basis for this build is the Revell boxing of the Italeri HAS3 with a touch of my own imagination.
One if the things I will have to do is scratch build the seats for the interior but I shall use the seats from the Italeri HU.5 as a guide. Another guide are a very nice set of drawings I found on the web which the kit appears to match quite well.
Had a slight misshap with the kit. Iv'e lost the window for the doorto the troop cabin  and don't have a spare :banghead:
So the question is does anyone have a spare I can get?
Quote from: Gondor on July 12, 2020, 09:19:54 AM
No spare, but if it just a square or rectangular side window, suggest scratching one up from a household recycling item. Sharp scissor or blade will do nicely. I have had good luck making flat replacement windows from clear plastic packaging such as this paint touch up package.  In fact sometimes it scales out better than the too thick clear plastic in many kits.  You can trim to fit, or in some cases make it larger than the opening and just tack to this inside of the kit.
Good luck!
Thought I better put up someking of picture to show what I am doing with this build. As the aircraft is a troop carrier for the Royal Air Force it was thought that there would be no reason not to have the troops the helicopter carried embark/disembark from either side of the cabin, so a prototype aircraft was constructed with doors on both sides so the troops could do just that.
Above you can see that I have started the hole in the side for the second door. The furthest forward window has been blanked off and filler applied to bring the blank and fuselage sides to the same level.
Below is the new door, the shape and window position were copied from the HU.5 kit I have. I used a mini drill to reduce the thickness of the door to take the spare window from the HAS.3 kit.
The thinning of the door is not perfect, it was my first attempt though and I believe I can manage to use this door rather than go to all the bother of making another especially if it was to be of two layers of thinner card or the same thickness as this one is, 0.03", which matches the kit door well enough.
Quote from: sandiego89 on July 12, 2020, 02:25:32 PM
Good luck!
It's an idea, but not one I hope to have to resort to. After finding the drawings for the HAS.1 and realising it should be possible to model one from the HAS.3 kit I could easily buy another HAS.3 thus having another window available. Would still like to get a spare from anyone who has one available though, just as a back-up. The main problem at the moment is getting the new door marked out accurately.
Humbrol's Cleafix could be an option - even though the window looks pretty large for the liquid stuff.
Quote from: Dizzyfugu on July 13, 2020, 01:10:35 AM
Roughly 0.5cm by 0.5cm Dizzy so I think so too.
The fuselage side door was cut out. Slight problem as it ended a little bit forward from where it should be due to the paper guide being slightly out of place. Fixable and I think the repair can be hidden which is also good.
I've thought myself that the Wessex should have doors on both sides.
Which is why I added one to my Sky Pirates build.
Interesting build. Yes it will be somewhat like that but with the earlier engines and the undercarriage from the kit rather than a Lysander.
Feel free to copy my paint job.   ;D
Quote from: zenrat on July 15, 2020, 05:11:28 AM
Err, nope
Going to be some kind of company livery as a private venture. Probably going to be a combination of two puke inducing colours as was typical of the period  ;D
TallEng
Quote from: Gondor on July 15, 2020, 06:11:45 AM
Err, nope
Indeed :thumbsup:
One could quite easily see imagine something like overall lime green with a chestnut brown Lightning flash style cheatline  :o
Keith
Quote from: TallEng on July 15, 2020, 01:33:22 PM
Err, nope
Indeed :thumbsup:
Keith
What a great sounding combination, I even have thouse colours in stock!  :thumbsup:
Managed to get a little modelling done on this. Had some success and some failure too. Started well with using a set of dividers to scribe where the door window was to go using the door from the HU.5 kit as a guide, I also scribed where the rear of the new door should be and easily managed to use my mini drill to power away the excess plastic, pity I hadn't though of how to scribe the dimensions earlier or I would not have had to add plastic to the front of the new door area due to cutting the opening too far forward  :banghead:
While checking the fit of the window into the HAS.3 door, I had to cut the hole out, I dropped the window. That's two lost windows for exactly the same thing, the doors  :banghead:
The good news was that I found it again, still don't know where the first window went  :blink:
The other bad thing that happened was that I made a real mess of the hole for the door window, so much so that I decided to add the window, partly to not lose it again but also partly to form a basis for filling in the gaps around it  :banghead:
No pictures of that door until I fill the holes which are so bad they make my scratched door to be a work of art  :rolleyes:
