avatar_TomZ
Messerschmitt Me-109TL-2
Started by TomZ, August 18, 2020, 11:24:26 AM
Interestingly, but, perhaps, not surprisingly, the left engine of both pairs sits forward of the right engine. ;) ;D
I am not sure I understand, but: yes, on slanting view, the jet closer to the observer is in front of the other on both sides:
Scotaidh
I thought you might have two in the middle between the fuselages - one on top of the wing and one under.  :)
Yes, it is very possible on a vectorial drawing but here on bitmap editing, I lack source for engines on the centerline. Maybe it is possible with morphing between port and starboard engines. I am not sure Corel Photopaint is able to do that. I will check, or maybe draw a vectorial equivalent, without TomZ's source (this would not be here as celebration). :unsure:
In my Corel Draw Home Suite software, I have found no morphing tool in the bitmap part (Photopaint) but there is one in the vectorial part (Draw itself), so I had to draw a vectorial view of TomZ's picture then a morphing created the central engine required by Scotaidh!: <_<
Scotaidh
Quote from: Tophe on August 25, 2020, 03:57:55 AM
Formidable!  Well done, my friend - it looks good.  :)
