G
Hawker 1216
Started by Geoff_B, January 22, 2005, 12:31:48 PM
Swamphen
Baa!
"Baaaa!"
Baa!
"Baa baa baa, baa baa we're lambs..."
:P
Wow, that looks great!
What engine was it supposed to use? Some Pegasus derivative with a straight pipe instead of the aft nozzles?
Zen
It was a brand new engine by RR, called the RB422 which gave 31,400lb dry and 44,600lb full PCB reheat.
A straight through version could have been a real alternative to the domance of the large US military turbofans.
P1216 data
Length: 55.9ft
Span: 34.75ft
Wing area: 421 sqft
Speed mach 1+ at sea level and 1.8 at 36,000ft (air combat role)
Weights where estimated at 31,000lb (air combat role 2 ASRAAM and 2 AMRAAM), assumably the max weight was far higher.
Wonderful! :wub:  Congratulations (to the modeller and designers)...
QuoteBaa!
"Baaaa!"
Baa!
:P
Didn't know you spoke Welsh  :P
Patrick H
Magnificent, where can I get one  :P
Patrick
My webpage
sidewinder
QuoteMagnificent, where can I get one  :P
Make that two!! :rolleyes:
Bryan H.
OOOH!  :wub:  Is that strictly for the UK or can friendly nations buy them?  Maybe, the Texas Navy could use some!  What's it's main mission?
:cheers: Bryan
My son & daughter.
School - finishing my degree
Models (upcoming):
RCN A-4F+ ArcticHawk
Geoff_B
Hi Bryan
The aircraft was intended to replace the Harrier and the Jag in UK service so mission would be similar to the JSF F-35B VTOL variant. Its capable of both Air to Air and Air to Ground and anti-shipping missions.
If developed then its quite possible the US would have joined in, they did with the Harrier after all, then again all the money went into high tech & stealthy when this design was being developed (1982-1987), but you can see it caertainly had potential.
Cheers
Geoff B
Geoff_B
Now where to start on doing the next one....
As we noticed from the generally positive feedback, Joe intends on having a go at producing one of these later this year. As a result i shall be adapting what i learnt doing the prototype into making some moulding masters for joe to use.
I know MartinH is intending to follow this build and hopefully do his own so i wonder is anybody else interested in following the build ?
If so then i'll list up the bits required later today.
Cheers
Geoff B
Martin H
QuoteI know MartinH is intending to follow this build and hopefully do his own so i wonder is anybody else interested in following the build ?
thats it,  Drop me in it  :P
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Scooterman
QuoteMagnificent, where can I get oneĀ  :P
Three!
Four or five or whatever!!!!!!!  I WANT ONE!!!!! :ph34r:  :ph34r:
Joe C-P
Where's the 1/700 scale one so I can load up my CVF properly?  ^_^
Speaking of which, where's my 1/700 CVF?  :P
JoeP :ar:
noxioux
QuoteHeres some shots of the 1216 prototype i built. (Prototype in that proving that it could be built, the actual moulding master for Joe will avoid the gaffs i made with this one  ;) )
Geoff B B)
"Gaffs?"
You must be joking------me no see any gaffs!!!
Fabulous and very gutsy!!!
:wub:  :wub:  :wub:
