avatar_Austanker
Suggestions / ideas wanted
Started by Austanker, August 30, 2020, 03:52:20 PM
That motorcycle chain idea looks ok. BNA Modelworld have it in stock.. but sheesh AUD $78 and a lot of construction work
https://www.bnamodelworld.com/for-motorcycle-other-scales-parts-decals-model-factory-hiro-mfh-p1099?zenid=35a240e933411c9e772fc82a102a5704
Would fine Brass mesh cut it as convincing enough?
Quote from: buzzbomb on September 01, 2020, 04:59:53 PM
It has to built up from individual rollers, pins and plates.  Insanity will be the result, mark my words.
Austanker
Quote from: zenrat on September 01, 2020, 03:58:55 AM
How about vinyl 1/35 Bren Gun Carrier tracks?
They are about 4 or 5mm wide from memory.  Thin enough?
If so, I have a pair from a Tamiya BGC you can have if you want.
I had the exact same thought but I would need to buy at least 3 kits , I like my spares but thats too much lol , thanks for the offer zenrat
Those motor cycle chains almost look good but a bit pricey
If you are in Aus and able to get out  :rolleyes:
Might be time for a trip to Spotlight or Lincraft. Those big craft stores have all sorts stuff, that can solve problems.
Stuff like textured ribbon, maybe something in the jewelery supplies. Sooner or later, somewhere you will see the very thing and have that Eureka ! moment.
Quote from: Austanker on September 03, 2020, 02:44:35 AM
No worries.  They are here if you change your mind.  I'm not keen on vinyl tracks and have obtained resin replacements.
Quote from: buzzbomb on September 03, 2020, 02:56:07 AM
If you could find ribbed material (rubber or vinyl maybe) then thin strips sliced off perpendicular to the ribs would look like toothed belt.
Austanker
I think I have found the solution will keep yas posted when they arrive from the US , little drive belts for R/C cars  :thumbsup:
Jesse220
