avatar_Dizzyfugu
DONE +++ Nakajima J9N1 "Kikka"; ATAIU SEA, Singapore, Jan. 1946
Started by Dizzyfugu, November 15, 2020, 11:48:45 PM
Quote from: PR19_Kit on November 23, 2020, 09:43:51 AM
Was there a 'code' for the fin markings, viz. B1-01 etc?
And were there other ATAIUs elsewhere as well?
I delved for the purposes of my 'background' Ki-61 - take a look at https://en.wikipedia.org/w/index.php?title=Technical_Air_Intelligence_Unit&oldid=918695585 and then check out the 'See also' and other links.  Especially http://www.risingdecals.com/DyingSun/DyingSun_A.htm.
All very interesting, thanks gentlemen.  :thumbsup:
I was wondering of there were ATAIUs in the Middle East to fit in with my S77 build, but apparently not.
I'll just plough on with it having been re-engined and pressed into service with the RAF in Egypt.  ;)
Quote from: PR19_Kit on November 23, 2020, 11:42:09 AM
IIRC someone on this forum advocates changing the backstory to fit the model, Kit, can't recall who  ;)
Surely the number of captured aircraft operated by Desert Air Force units could justify a whifworld detachment of the https://en.wikipedia.org/wiki/Air_Fighting_Development_Unit_RAF operating in that theatre?
Great job Dizzy!
Agree the hand painted marking are very tough to pull off- I had similar problems with my WHIF Horsa for the Japanese homeland invasion- but you really pulled it off!
-Dave
Quote from: Dizzyfugu on November 23, 2020, 10:18:12 AM
I am not certain about the tail code. I always thought that it was the original Japanese code, just ignored by the new operators, but now with the two types side-by-side in the pics it appears as if the BI-XX code is actually an ATAIU item code? No idea what the "BI" means, though. I know that german aircraft carried "FE-XXX" codes, for "Foreign Equipment", so I adapted it for the Kikka.
BI  -  British Intelligence ?
Quote from: rickshaw on November 23, 2020, 03:50:10 PM
That would have been my first guess, too.
According to this (top secret) source, the RAF also tested the Twin-Kikka: <_<
Thanks! ;D
The picture copy joke deserves not much, all the merit is deserved by your source model. :thumbsup:
BI- was originally the code for the aircraft carrier Soryu, some of the shipboard
unit designators were later reused by land-based units.
In this case they're probably a reference to the captors.
After doing some digging around it appears that single-engine types and smaller twins
received a 'B' code: B1 fighters; B2 trainers. Larger transports and bombers coded F1.
At least that seems to be the current consensus based on available information.
Some known codes:
Type Tail code
J2M   B1-01
J2M   B1-02
A6M  B1-05
A6M  B1-06
A6M  B1-12
A6M  B1-21
A5M  B1-32
K9W  B2-20
K9W  B2-21
A6M  B2-51
G4M  F1-11
L2D  F1-23
L2D  F1-27
Following this format, a Kikka would most likely have had a B1 code.
