Lockheed/Bell AV-56 Cheyenne
Started by CammNut, November 29, 2020, 10:39:31 AM
CammNut
When Lockheed encountered development challenges with the rigid rotor of the AH-56 Cheyenne attack helicopter, which led to the fatal crash of a prototype in 1969, the U.S. Army notified the company it would cancel the program if the problem was not solved. Lockheed proposed a redesign of the rotor control system, but Bell quietly stepped forward with an unusual solution: replace the rigid rotor with a tiltrotor propulsion system.
Bell had been looking for an application of the tiltrotor since demonstrating the concept with the XV-3. Applied to the Cheyenne, the tiltrotor not only eliminated the rigid rotor's problems, but increased performance and overcame the persistent weight issues. In effort to avoid Congressional scrutiny, the Army chose not give the redesigned Cheyenne a new designation from the V-series, but instead just renumbered it the "AV-56" in a bid to play down the extent of the changes.
This is my first whiff attempt since I broke my arm this summer, so I kept it simple. I saw some folks here put the Bandai Gundam tiltrotor pack to good use, so I bought one. Then I saw that Atlantis had released the ex-Aurora 1/72 AH-56, so I bought a couple of those. The Bandai tiltrotor looks a bit retro, so I thought it would make a good match to the Cheyenne.
The wings on the tiltrotor pack are quite short, so I created a new wing center section from plastic card. This sits on top of the fuselage where the single turboshaft engine and main rotor pylon were. I eliminated the tailrotor and tail propeller, cut off the Cheyenne's wings and instead added smaller stub wings that would carry the weapons (had I bothered to arm it). I added IR jammers to cover seemingly pointless holes in the Bandai nacelles. The decals are from the kit.
Awesome job!
I could see this in Marine colors escorting MV-22s to the LZ! I know that's playing with the timeline but it would look cool. Just say there was a bunch of airframes forgotten in the back corner of the "boneyard" in AZ.
Hmmmm....    I have the Cheyenne kit in the stash maybe I should get busy.
What an excellent job you've made of that, both the model AND the backstory!  ;D :thumbsup:
Wow :wub: I  really like that. Marvellous  :thumbsup:
AeroplaneDriver
Beautiful work!  That just looks soooo right!   :wub:
Ah, the versatile Gundam tiltrotor pack! So many uses...  ;D
Great application, looks pretty sleek and fast.  :thumbsup:
Nick
Fantastic!
I can see a USMC version over Grenada in 1981, or escorting the Jolly Greens at Desert One.
63cpe
Excellent whif! As Dizzy wrote: that looks pretty sleek and fast.  :thumbsup:
Thanks for sharing with us!
David aka 63cpe
I love it ! Great build and an even better idea ! I can see a similar build in my future. Cheers !
frank2056
It looks so modern! Great combination of parts. It almost looks like it could be in Avatar...
CammNut
Thanks for the comments, folks. It's pleasing when whiff comes out "looking right"
