avatar_Tophe
Update for "The end of Forked Ghosts"
Started by Tophe, January 29, 2005, 10:03:56 AM
Well, the F-78H and L were not interesting for the USAF :( , but they were interesting for us enthusiasts and modellers :) ... Mainly: the 78L with low wing would have booms so low, even above the wing, that a T-tail would have been mandatory, for the trucks to approach freely. Different Packet... maybe for JHM Senior, RCAF. ;)
Quoteas the fuselage was a disposable container
I have received from Belgium new data about the SR-45 (and probably the R-45 before 1945): either there would have been a rear door as I have drawn previously, with a ramp for a car to climb, classically, OR the whole rear part would have been removed, and towed on roads.
Differences with the late US XC-120:
- the R.45 kept a classical nose wheel
- the landing gear would be short, light, solid, stable
- removing the cargo-pod could be done only rearward
- the pod could not be released with a parachute while flying
But for fun, I draw as flying the podless R-45, above a normal podded one... Impossible? What-if the pod had been delivered and before it came back empty, an emergency evacuation (matter of life and death with killing armies invading) was obligatory: the empty R-45 may have tried to take off...
Quote- the R.45 kept a classical nose wheel
Other news from Belgium: the C-119 has been considered also as the SR-45, not low-wing but with a removable pod to be towed away rearward and keeping a nose wheel (before the USAF required front-and-aft removing of the pod, leading to the 1948 patent and building of the XC-120).
As the C-119 was first known as C-82B, flew in 1947, this special pod version of the C-82A (C-82P?) could be dated as somewhen in the range 1943-1947 (and the middle of it is 1945). Yes, just unsure, provisional.
In the August-2005 issue of the magazine Le Fanatique de l'Aviation, I have read that the USAAF had wanted to replace its F-5 (foto-reco version of the P-38 Lightning) by the P-58 Chain-Lightning in a foto-reco version. Maybe this could have been a two-seater like the XP-58, with just addition of cameras (and unchanged layout) OR this could have been a high-speed single-seater like the P-38/F-5: see my provisional drawing RP-58 below.
QuoteIn the August-2005 issue of the magazine Le Fanatique de l'Aviation
In the same magazine, it was mentioned that the Hughes attack version XA-37 (from the pursuit XP-73) may have been coded  Design D-3 (from D-2). And the derivative XF-11/R-11 (from D-5) came from a 3-seater version with bigger fuselage and/or  a rear remote turret (XD-5? as the D-2 was also mentioned as XD-2 and DX-2).
I understand the Hughes XD-5 above may shoot its own tailplane instead of the enemy behind. So a XD-5' with separate tailplanes may have been proposed, but all the strength calculations would have needed an update, as the layout is far less solid without rear link. Other possibility: XD-5'' with the turret on the tail, but how to justify the twin-boom layout anymore? (a central fuselage would have been more appropriate for such a central rear weight).
I had ordered Justo Miranda's Unknown No.4 at http://www.luft46.com/rd/rdreams.html and I received yesterday. Very interesting... Most of all, for myself, a 3-view drawing of the Davis Manta, with lots of new explanations. I must correct my initial drawing (Manta-1 below) with the crescent-wing and bubble-canopy (Manta 2 below). I may add that it was a 1940 design of David Davis, with the name Bat at first, and the central double-engine could be replaced by a centrifugal turbojet (Manta-3 below); then in 1942 was created the Manta Aircraft Corporation to build the final design, keeping the crescent wing and double-propeller, but no more as pusher with twin-booms but as tractor with classical fuselage (P-75 like). Probably, in between, was considered a push-pull way (Manta-4 below), the 2 shafts from the double-engine going in opposite directions rather than in parallel.
QuoteI had ordered Justo Miranda's Unknown No.4 at http://www.luft46.com/rd/rdreams.html and I received yesterday. Very interesting...
In the same booklet was a 5-view drawing of the twin-engined P-40, nice! This makes me correct my drawings of P-40T and T'' into P-40TE and TE''. Unlike the twin-engined P-40, these twin-boom derivatives of mine are not real projects, just mistakes, reading Supertom's 'wrong' words (but thanks! :) ) about a Real 'twin-boom' P-40, and I had not made enough checking before drawing my interpretation. :(  :)
As seen above, the low wing was very imperfect for the XC-82 (and Ki-105 equivalent), because rotating blades needed not to hurt the ground, thus high engines, thus rather-high wing, thus (for a low wing) a rather high fuselage, difficult to reach for heavy loads, climbing from the ground.
BUT for a cargo glider, as the Ku-7, it was very different: both wing and fuselage could be very low, thus allowing :
- a short main landing gear in the booms, without very long (heavy & fragile) gears from a high position;
- a wide very stable main landing gear, from the wing, without narrow position from the central fuselage;
- a drag-less cumber-less main landing gear, needing no special pod when retracted, nor room in the fuselage.
It is almost sure that such a layout has been considered among the first Nihon-Kokusai designs leading to the Ku 7 order. Probably the high wing was selected at last in case a twin-engined derivative would be ordered next, which actually happened. Like for the SAM-23 that we will see next.
The provisional drawing above is what-ifingly named Ku 7 Kai, as possible derivative, in case it was proposed again when the test pilots of the Ku 7 said the balance was awful, dangerous, with the narrow landing gear.
As well, this Moskalev SAM-23' cargo-glider with a low wing is not 'proven-true' with Historic sources, but very probable as temporary drawing (before considering the SAM-24 twin-engined derivative):
To the list of non-genuine twin-boomers designed 1939-45, I must add the derivatives of the SNCA-SudEst SE 500: SE 600, SE C1, SE Trimoteur-30t, all were triplex-boomers, with a main central fuselage holding the tailplanes, while little extra-booms were linking fins and wings (and engines on the 3-engined Trimoteur and 2-engined 500). It would have been possible to design actual twin-boomers from that, truncating the central fuselage for a rear post or rear door or rear engine or rear jet pipe.
In my book "Forked Ghosts" were presented all the twin-boom PROJECTS designed in 1939-45 (that I knew), not the famous IN-SERVICE twin-boomers of WW2. Though most of the leading twin-boomers 1939-45 were not hidden, as presented through derivatives: but one was absent, the Fokker G.1 – its initial project Ontwerp 129 is dated 1936, the glazed-nose derivative T-VI project is dated 1937 as well as the Super-G.1 and the G.2 (Ontwerp 135 & 154), so all far before 1939.
HOWEVER I have read today, in the old magazine Le Fana de l'Aviation Nr 125, that 16 copies of G-1B has been transferred in Germany in 1940, with deep interest. Maybe they were seen as very good two-seat fighters, better than Bf 110s, and considered for German production, with standard German engines of that time: Daimler-Benz DB.601. Thus the provisional G.1DB below:
Provisional drawing: the Vultee XP-68 Tornado project (cancelled in 1941) was a late derivative of the XP-54 (first flown in 1943...). The engine would have been a 42 cylinders Wright R-2160 Tornado (? with 6x7 cylinders, thus much longer and narrower than the R-2800 Double-Wasp of 2x9?). I have read that this radial was surprisingly liquid cooled, in order to cool down even the rows far away from frontal area, while radial layout was chosen for maximum power.
Here is an unknown twin-boomer found at
http://www.tgplanes.com/Public/snitz/topic...sp?TOPIC_ID=784
The markings suggest a US plane 1943, as true industrial project or true artist dream of those years, far away from our anachronic what-if inventions.
Note :
- the engine seems central, air-cooled, while the propellers are lateral, in front of the booms
- the weird shape of the fins (all below) is not explained, and the advantage of such a layout is difficult to imagine... engineer Elmayerle?
I am trying to reach the one that posted this picture, to know the precise magazine issue and picture title (maybe with the manufacturer/model names...)
QuoteProvisional drawing: the Vultee XP-68
A friend has told me he had read the XP-68 had a ventral airscoop. Well, maybe the main one was ventral with 2 side scoops to complete, or there may be a single low one – I present the latter as XP-68B (B for Belly, of course).
