avatar_The Rat
High altitude Lancaster
Started by The Rat, January 30, 2021, 11:00:16 AM
I'm sure that this has been thought of before, maybe even modeled, but I haven't seen it, so here's the idea: Inspired by the 14,000 ft increase in altitude offered by the B-17, Avro gets to work on a Lancaster variant that can attain a similar altitude. To my mind (such as it is  ;D) the obvious mod would be the same as what spawned the Lanc from the Manc; another rectangular section, this time outboard of the inboard engines. This obviously increases the span, giving more lift and a lower induced drag due to the higher aspect ratio. A (very) crude bash of a 3-view gives us this:
High altitude lancaster by Dave Bailey, on Flickr
Fuselage extensions may also be possible, so long as the increased weight does not compromise the quest for altitude. The supercharger would need to be modified for such an altitude, as the standard Merlin one was calibrated to operate best at 19,000 ft., if my sloppy research is accurate.
Since I'm rather technically challenged, to put it mildly, I'm probably missing some obvious things, so if anyone wants to improve, criticise, laugh (but not too loudly), go ahead.
My avro  Kittleton is  going to be a high altitude bomber  with 6 Griffon engines, to help overcome  problems with  thin air at altitude  it would  have nitrous oxide tanks in the fuselage  to give the engines a helping hand. Maybe  this could  be used on your Lancaster  Rat?
Shackleton wings could help with Merlin engines , although a  bit of work needs to be done to get the engines to fit on the undersides of the new wings.
IIRC The Wooksta did one like this some years ago, in blue and grey.
How about a fifth engine (as in the prototype Pe-8), mounted in the fuselage over the bomb bay driving a compressor supplying compressed air to the rotor tips wing engines and a pressurised crew capsule?
Ah yes I remember that now  :thumbsup:
We obviously had a nice little "cellar" behind the What If banner as well  ;)
That's the one I was thinking about, yes.
VERY impressive.  :thumbsup:
And huge with it!  :o
Is that a Avro Vulcan canopy with what looks like a Avro Lancastrian nose?
Revell new tool Lancaster, with Lancastrian nose and tail cones.  Deep bomb bay (a Tallboy dropped from 40,000 is going to go through ANYTHING!), underside turret & fairing.  Lincoln rudders.  Wings and engines from a Shacklton.  Yes, Vulcan canopy.
Do one up high-altitude Wimpy style, Mk. V type of course as its longer more streamlined
fairing is more attractive. Turbosupercharged Merlins or Hercules, of course.
Erm, I did, if you click the link in my earlier post...
Quote from: The Wooksta! on February 02, 2021, 11:02:16 AM
Yes, I saw your post, and I remembered the build, but I'm speaking more explicitly resembling
the high-altitude Wimpy by also using a cylindrical pressure cabin.
The real Avro Type 684, it had a fifth Merlin behind the fuselage scoop. Used for pressurization and turbo-charging the other four engines.
