avatar_63cpe
How to make a drum from a concrete mixer
Started by 63cpe, February 10, 2021, 01:48:39 PM
63cpe
Hi All,
In need of some idea's how to make a drum from a concrete mixer. Size is rather small about 1,5 cm in length and 3 cm diameter at it's biggest. The unequal tapered shapes are the trouble. Even considered buying a mixer toy but can't find any info on the toys nor the drum.
Maybe someone can point me in the right direction?
David aka 63cpe
For something that small you could use a drill as a mini lathe.  Clamp the drill then mount a bit of plastic on a drill bit.  Use sandpaper to shape it at a slow speed.
At first glance at the subject line I thought you were talking about Caribbean steel drums made from 55 gallon barrels except really huge!
There used to be an adhesive glue in the shape of a concrete mixer,  I can't remember the product name.
tigercat
Is there any lego of right size and shape ?
Maybe a Yakult bottle? Might be too large in diameter, though. But these things have a vivid scratch-building history in Japan!  ;)
Just to be clear, do you want to build the drum from one of these...
...or one of these...
perttime
What kind of a drum are you making?
Have you checked the grocery store for suitable shapes?
Quote from: zenrat on February 11, 2021, 02:09:53 AM
There was a glue bottle container in the shape of the bottom picture.
63cpe
Hi All,
Thanks for the replies. Yes it need a drum/kettle thing for the lorry type concrete mixer. So the large ones.
@Dizzy, that's a good suggestion to check the Yakult bottles. I haven't been to the groceries yet (busy at work and very limited opening of shop due to auntie Corona) but will do.
Hobbes offered me to make a drum/kettle-thing with a lathe. But will try the Yakult bottle solution first.
I have plans with a derelict CH-54 and yes, this is for the upcoming GB. :o
Erickson just started an aerial construction department  :thumbsup:
David aka 63cpe
An airborne concrete mixer?  :o
Whatever next!
63cpe
yeah, just..why not?! :mellow: :mellow:
LOL
David aka 63cpe
tigercat
If not the railway modellers probably have a kit you can steal one from .
63cpe
