avatar_ysi_maniac
Civilian Street Cars
Started by ysi_maniac, April 01, 2021, 07:21:12 PM
Quote from: jcf on May 23, 2023, 10:15:13 AM
Quote from: Rick Lowe on May 22, 2023, 10:25:22 PMY'know, I can see that as a WW2 staff car... not sure which nation, though.
Germany for Goering, the second rear axle being added to carry the weight, which is the only reason you'd add a second dead axle to a front wheel drive car.
;D
;D  ;D  :thumbsup:
Well played!
You can choose where the engine/s is/are. ;D  :o
The 2CV Sahara had 2 engines, one in the usual place and one in the back, driving the rear wheels. A few hundred were built.
What were the benefits of having two engines ?
perttime
Quote from: NARSES2 on June 08, 2023, 12:15:38 AMWhat were the benefits of having two engines ?
Four wheel drive, or you could run it on either engine. That gives some redundancy too.
Power output doubles, from inadequate to barely adequate.
 :mellow:
When I was working as a security guard at the BBC  West Acton they had a modified 2CV,the engine had been replaced with batteries and they used as a runabout. It was the Outside Outside Broadcasting Unit.
Quote from: zenrat on June 08, 2023, 04:28:38 AM
 :mellow:
Ah, right  ;D
IIRC Citroën Sahara was a military project.
Any car can be improved by fitting ANOTHER engine!
That's in addition to the one already there..........
Reminds me of a nuts Opel Corsa Mk. I dragster I have seen in a German TV documentary many moons ago, which had two tuned turbocharged Opel Calibra engines - one in the front, the other replacing the rear seats, and each driving an axle separately. Total output of almost 1.000 hp How the hardware was mounted into the tiny car is still a mystery to me, and to make matters worse it had IIRC a UK registration and was even street legal!
They wanted a car that could be used in the desert, so they needed 4WD. The standard 2CV engine is rather underpowered, and drive train losses for a conventional 4WD system would have made it unusable. The alternative would have been to fit a larger engine, re-engineer the bodyshell to accept the driveshaft down the middle, etc. Fitting a second 2CV engine was simpler.
Quote from: Dizzyfugu on June 09, 2023, 07:31:09 AMReminds me of a nuts Opel Corsa Mk. I dragster I have seen in a German TV documentary many moons ago, which had two tuned turbocharged Opel Calibra engines - one in the front, the other replacing the rear seats, and each driving an axle separately. Total output of almost 1.000 hp How the hardware was mounted into the tiny car is still a mystery to me, and to make matters worse it had IIRC a UK registration and was even street legal!
Looks perfectly reasonable to me.   ;D
Specially as it's a Vauxhall............
Quote from: Hobbes on June 07, 2023, 11:34:05 PMThe 2CV Sahara had 2 engines, one in the usual place and one in the back, driving the rear wheels. A few hundred were built.
Is this really a CLOCKWORK 2CV?  It seems to have a hole for the winding key  in the (LHD)  drivers door.
