avatar_buzzbomb
Re-engined Fairey IIIF - 1/72 Vacform
Started by buzzbomb, June 09, 2021, 06:13:22 PM
For a GB on BTS I have fossicked out an old Contrail Fairey IIIF as the basis for my build. What I am thinking is a late service Fairey IIIF, maybe used by the Irish Air Corps, but re-engined with with a more powerful radial engine.
Now, why I stopped building is lost to the dim dark past, but I think this..... is part of the reason
Engines.. well turns out to keep in the 20's 30's zone I have a bit of choice in the spares tin
Bristol Pegasus -
Bristol Jupiter - looks a bit like a PO-2
And the Perseus nicely cowled.
At this stage the Cowled Perseus is winning by a bit as it does look cool. Well they did with the Bristol Bulldog for Finland with a Bristol Mercury.
In fact having said that, maybe a IIIF MK VI with a Bristol Mercury in Finnish Markings would work as well.
A Contrail Fairey IIF?  :o
You really are a glutton for punishment, aren't you? Having said that, the work you've done so far on it looks IMMACULATE! Most impressive.  :thumbsup:
Quote from: PR19_Kit on June 09, 2021, 08:55:14 PM
My sentiments entirely
:bow:
An interesting world of British 20's-30's aircraft. Also did some more digging around getting background of engines and the IIIF or its heirs and successors tried quite a few.
Fairey Seal, Fairey Gordon, direct descendants, with different engines. Then there was sales to overseas buyers, often with a different engine.
It was almost that my proposed whiffer was a RW model  :o.
So back to work on the III <whatever>
No problems about redoing the awful injection stuff. That had been decided very early
Replaced the landing gear with brass and Aeroclub strut. Much easier
Revisited the rigging holes
Whacked in some new struts to the replace the 4x2 rough sawn timber looking things that had been supplied with the kit.
Plus another engine trial option. Something with a cowl is still winning methinks.
Doug K
Definitely a cowl, but great work on the undercarriage
Work proceeds
Basic paintwork with the Irish Air Corps markings of the time
let the mess of rigging commence. Pre-drilled holes in the wing, then superglued in rigging thread. On this model I am trying something a different technique as a trial, where the upper wing has holes all the way through, glue then re-finish.  Or should that have been the lower wing  :-\ We shall see
Never having added rigging to an aircraft myself, I would have thought that fixing the finish on the upper side of the top wing would be easier as it's convex where as the underside of the lower wing is most likely concave and thus more difficult to deal with.
But if you male a mess of it the underside of the lower wing is hidden whereas the top of the upper wing is the most obvious place possible.
Quote from: zenrat on June 23, 2021, 05:12:10 AM
I know, bit of a rock and a hard place. This is partly why I don't usually do biplanes and certainly not rigging if at all possible, which is usually always.
I only ever built one biplane in my life, EXACTLY for that reason. Those wires would drive me crazy!  :banghead: :banghead:
Doug K
Quote from: PR19_Kit on June 23, 2021, 05:57:15 AM
Yep, I've given up on my Stranraer for now, I foolishly thought it would be easier than my Gladiator & Siskin because it is bigger......
The word you were looking for Kit was CRAZIER!  :rolleyes:
