avatar_zenrat
Oswald Bastable - Mounted Reconnaissance. Finished pics pg 7.
Started by zenrat, July 09, 2021, 04:28:26 AM
54mm "toy" soldiers tended to be fairly consistent when it came to size, but 54mm "model" soldiers varied between manufacturers. Some measured ground to eye, others foot to eye and there were other yardsticks used. Then of course you also had 2 1/2" scale  :banghead:
Exactly the same problems with Wargaming scales, indeed probably worse.
crudebuteffective
Quote from: NARSES2 on August 16, 2021, 06:26:49 AM
airfix 54mm napoleonic models also have a scale problem between figures
the mounted figures are closer to 1/32 and the foot figures are close to 1/35
Quote from: crudebuteffective on August 16, 2021, 06:36:37 AM
Yup, often wondered if it was down to the sculptor ? I assume there were a few different sculptors involved ?
Nick
Quote from: zenrat on August 16, 2021, 04:05:56 AM
Quote from: PR19_Kit on August 15, 2021, 05:23:59 AM
Erm, isn't that rifle he's carrying a little 'modern'?  :-\
This is a Steampunk build remember.
And anyway, i'd hardly describe the AK47 as modern.
However, I may end up not using the Kalashnikov as it looks a little small.  This is due to the gun being 1/35 while the figure is "54mm".  A scale that allegedly equates to 1/32 but seems, like all scales quoted as a length, to be variable.  The head (1/35) doesn't look too bad but the hands are huge.  Problem is that 1/35 hands (I have a set of spare resin hands - who doesn't?) look far too small in comparison to the sleeves.
I may end up doing away with the whole upper body and using 1/35 parts instead.  It would be a shame though as I Ilike the frogging on the Hussar jacket.
Have you considered weapons from Warhammer 40k, Primaris or any of the dozens of copy firms? These are bulky, 54mm scale and look steampunky.
There's always these if you feel rich... https://www.shapeways.com/product/2E2LD2S2B/54mm-dark-future-weapons
Thanks Nick.
I have taken the drastic route and decided to swap the entire upper body for 1/35 parts from a variety of WW2 sources.  Torso, from Tamiya, is in place.
Quote from: zenrat on August 17, 2021, 05:15:45 AM
That's a shame, I was really liking this look. Tweaking the Hussar Carbine  with a magazine and rudimentary lever action may have been a solution.
Still, whatever you do will come out just fine, pretty sure of that.
Your build here has caused me to recently fossick out my box of 54mm Napoleonics, so do not be surprised that you have sparked a bit of inspiration here. Thank you. :thumbsup:
On the 54mm variation topic, Historex appeared to be the class leader, their moulding was much finer, but at the same time I would think their target market could bear the higher price point.
Well, I still have the relevant parts. They may make a reappearance at some time in the future.
Quote from: buzzbomb on August 17, 2021, 04:13:18 PM
Oh that stirs some memories  :thumbsup:
Oswald Bastable take two.  Torso by Tamiya, arms by Master Box.
10th Hussar 1815 WIP 21-08-2021 by Fred Maillardet, on Flickr
I've got a number of 1/32 WW2 weapons from Airfix multipose sets for when you revisit the Hussar body?
Quote from: Mossie on August 21, 2021, 04:43:15 AM
He looks in a very realistic pose, nice and animated  :thumbsup:
Thanks Chris.  That was my aim.
Nice! :thumbsup:
Looks in keeping with the 19th Century "bigger is better" axiom re: rifle calibres/bores - just before smokeless powder & high-velocity projectiles came into fashion. ;D
