avatar_zenrat
Grumman NRA-6A Trespasser - Finished Pics Pg 5.
Started by zenrat, July 25, 2021, 02:17:25 AM
"Real deal" stuff happening right there! :thumbsup:
Thanks folks.
Quote from: NARSES2 on September 10, 2021, 07:17:20 AM
Quote from: DogfighterZen on September 10, 2021, 05:53:33 AM
What a beauty!  :thumbsup:
She is indeed ?
Do you paint the cockpit in situ Zen ?
I usually paint before closing the fuselage but not in this case.  The tub can be inserted after closure so I can paint it before gluing it in.  The Hasegawa Intruder is bereft of cockpit detail so I have added some greebles.
Cheers.
I only ask because I've started to pre-assemble and paint larger sub assemblies than I did until quite recently. Find it helps to use normal glue rather than super glue on small parts given my hand/eye coordination issues. Also helps that I recently found some of my really fine wargame figure painting brushes from eons ago  ;D
The canopy on this is terrible. Two halves split longitudinally.  Vey soft raised frame detail.
Some floor polish helped make it look clearer but not having a masking set I was forced to mask with thin tape.
We'll see tomorrow how successful I was.
Thanks Dizz.
I unmasked the canopy today.  All good.  One minor clean up needed where i over-ran the tape but I was using acrylics so it scraped off easilly.
Canopy and interior test fit.
Trespasser WIP 16-09-21 by Fred Maillardet, on Flickr
Transfers. All, apart from the squadron insignia on the tail, sourced from the Viking.
Trespasser WIP 18-09-21 by Fred Maillardet, on Flickr
Started work today on the belly mounted camera pod and painting the drop tanks.  I have dropped the plan to use Hasegawa's MERs and bombs because the bombs are such odd shape.
That really is looking brilliant, Fred! :mellow: :bow: :bow:
Quote from: zenrat on September 18, 2021, 04:03:37 AM
DAMN!!  :o
That is coming out really well!
Definitely looking like a "should have been"!
Excellent work!
That's coming along a treat. Looks natural!  :thumbsup:
MiB
Fred, amongst your best yet.
To my way of thinking, there are times when the subtle changes, enough to make folks do a double take, look again more closely and question what they think they know is more satisfying than an off the wall build.
