avatar_Lost Cosmonauts
Lost Cosmonauts' 3D printed what-if playthings and emporium
Started by Lost Cosmonauts, August 11, 2021, 07:12:21 AM
Lost Cosmonauts
Hi folks, I've been pointed toward this forum to share my builds a few times so finally took the plunge.
I'll do a kind of catch up post here and then add to it as I go along.
To save on some of the background as to when and why I got back into model making you can read a bit about me here https://uk.airfix.com/community/i-build-because/alistair
Anyhow, a couple of years ago my eye was caught by this bookazine in a WHSmiths
That got me thinking about scratch building but as I'd been musing about 3D printing as a way of adding to models I bought it and then started a little project of making digital designs and prints of these planes that were wholly new to me.
Working with a FDM printer (the kind that uses filament) and first tinkercad and then Fusion 360 I worked on some steadily more complex shapes
Miles M.52
XP-92C
Then from the bookazine
The RAE type with engines in the fuselage
The RAE type with engines in nacelles
I even had a go at the Fairey Delta 3 cover star
Fuelled by that (and encouraged by The Good Mr Wooksta and then TSRJoe) I branched out, bought some more books and started on some other designs
DH110
Vickers Type 582
DH108
More to follow shortly
Lost Cosmonauts
^honestly there were meant to be pictures up there^
Anyone able to help explain how to make flickr and this forum play nicely together?
Sorry, I use SmugMug, but I did notice that Flickr didn't put .jpg or .jpeg, etc. at the end of the link. :unsure:
Lost Cosmonauts
#3
Quote from: Old Wombat on August 11, 2021, 07:32:58 AM
Thanks, altering the url to include the file type seems to work. I'll work through and edit them all
That's some impressive work! Welcome aboard the crazy train! (Cue Ozzie)
There are a great many interesting items here.  Welcome to Whiffworld, you belong here!
I've been called many things in my time - some of them even pleasant - but good? Lies, all lies.
Seriously, currently cleaning up the prototype P.8. It'll need some more sanding, plus strategic use of hot water. Hopefully will have it together by Sunday.
Nice CAD work. The models cleaned up well for an FDM printer.
Keep up the great work :thumbsup:
Lost Cosmonauts
Quote from: kerick on August 11, 2021, 09:46:18 AM
Very much appreciated, thank you
Quote from: Pellson on August 11, 2021, 10:15:51 AM
Oooh, that FD3... :wub:
Should be available as a kit toward the end of this year - I need to figure out the undercarriage bays and drooping cockpit section
Quote from: Rheged on August 11, 2021, 11:07:38 AM
Thanks, I love the early jets and how daring some of the designs were. Expect many many more
Quote from: kitbasher on August 11, 2021, 01:21:23 PM
EE P8 and DH127 please!
All over that like a rash
Quote from: The Wooksta! on August 11, 2021, 03:10:43 PM
Jeez, that's quick work! - looking forward to seeing how it turns out and hopefully I'll be able to incorporate any changes into a neat finished version
Quote from: buzzbomb on August 11, 2021, 04:14:32 PM
Cheers! The FDM printer was fine as far as it went but as you say they needed a fair bit of clean up. Layer lines and resolution were a bit of a sod so I got hold of an Anycubic Photon Mono DLP printer so I could try and improve things a bit. Still working up the breakdown of parts and how to best print the models but a few in the works
Miles M.52
English Electric P.8 (now in the good hands of Mr Wooksta
Armstrong Whitworth AW.58 delta winged version (off to a test builder and awaiting pictures and feedback)
Armstrong Whitworth AW.58 swept wing version (heading out today to a test builder)
You and me both  :wub: and I don't normally stray into this period of aviation history.
Marvellous way to introduce yourself, welcome sir  :thumbsup: :thumbsup:
frank2056
Great models! Resin printers are a step up from FDM and mono printers are a step up from RGB screen resin printers!
What resin did you use for the Miles M.52 canopy/forward nose? It looks very clear. My attempts with Anycubic clear resin yellowed quickly and weren't very clear, although either a dip in Future or clear resin (then re-cured) might have helped.
Lost Cosmonauts
#13
Quote from: NARSES2 on August 12, 2021, 06:15:33 AM
Thank you very much
Quote from: frank2056 on August 12, 2021, 10:34:52 AM
Cheers, for both the clear and opaque I've been using the Anycubic Eco which is their newish material based on an acrylated soy oil. It comes out misty because of the surface texture but like you say applying a clear coat inside and out improves matters considerably. On yellowing a thorough post cure with a UV lamp might help as often (or at least in the case of paints) yellowing is because of residual double bonds reacting with oxygen in the air. You often see it with old style solvent borne alkyd emulsions and gloss paints (dark yellowing) which is improved by exposure to sunlight. I've not heard of the same thing in acrylics but might be worth a try
Lost Cosmonauts
While I await the results of folks building the AW.58s and the P.8 I spent some time adding legs to the next planned print
