avatar_zenrat
Boulton Paul Defiant PR Mk I. Finished Pics Pg 4.
Started by zenrat, August 28, 2021, 04:27:01 AM
The Dagger works quite well on a previously Merlin-engined airframe actually.
The canopy definitely has an IL-2 vibe. Pilot and another crew member close enough together to shake hands? How very unBritish!
RTOOD2....LOL  ;D  :wacko:
2996 Victor
Quote from: PR19_Kit on May 11, 2023, 06:32:08 AMThe Dagger works quite well on a previously Merlin-engined airframe actually.
Like it! 6.Sqn Dagger Defiant Mk.IID? And Vickers 'S' guns - now that would have been a what-if!!! Poor old Erwin would have been caught with his panzers down  ;)
Mark
Mark's workbench:
Spitfire Mk.I Vichy North Africa - Eduard 1/48
Spitfire PR.XIX Rearward-cockpit - Airfix 1/48
Boulton Paul Valiant Mk.I PR - Airfix 1/48
Quote from: 2996 Victor on May 11, 2023, 08:03:01 AMLike it! 6.Sqn Dagger Defiant Mk.IID? And Vickers 'S' guns - now that would have been a what-if!!! Poor old Erwin would have been caught with his panzers down  ;)
The build thread and backstory's here. https://www.whatifmodellers.com/index.php?topic=48076.0
KP Sabre cowlings appear to be not significantly wider than Hasegawa Allison cowlings.
Photo in my blog page.
Back in about 1961 or 1962, a very much younger Rheged converted an Airfix Defiant into a single seater with a single "large tank-busting gun" under each wing and  rockets borrowed from another kit (I forget which....but they were jade green and might possibly have been from  a Heller Alize).  This was my first ever whiff.............but it was not a great success as I had not at that point learned the dark art of PSR.      Kit's current iteration of a Defiant flying tin-opener is a delight to see, and a cogent backstory with it!
Quote from: kerick on May 11, 2023, 06:40:53 AMThe canopy definitely has an IL-2 vibe. Pilot and another crew member close enough together to shake hands? How very unBritish!
I think this might have been permissible  BUT ONLY IF THEY HAD BEEN FORMALLY INTRODUCED TO EACH OTHER AND/OR WORE THE SAME OLD SCHOOL TIE.
Quote from: Rheged on May 12, 2023, 08:10:03 AMI think this might have been permissible  BUT ONLY IF THEY HAD BEEN FORMALLY INTRODUCED TO EACH OTHER AND/OR WORE THE SAME OLD SCHOOL TIE.
ABSOLUTELY old chap! One has to maintain one's standards after all!  :o
2996 Victor
Quote from: PR19_Kit on May 11, 2023, 08:30:40 AMThe build thread and backstory's here. https://www.whatifmodellers.com/index.php?topic=48076.0
Excellent! I do like the premise of a beefed-up Dagger and the whole Defiant tank-buster is a brilliant idea, plus it looks great in desert camo!
Quote from: zenrat on May 12, 2023, 05:49:21 AMKP Sabre cowlings appear to be not significantly wider than Hasegawa Allison cowlings.
That opens up a raft of intriguing ideas (list of V-1710 aircraft pinched from Wiki):
Bell FM-1 Airacuda
Bell FL Airabonita
Bell P-39 Airacobra
Bell P-63 Kingcobra
Boeing XB-38 Flying Fortress
Curtiss P-40 Warhawk
Curtiss-Wright XP-55 Ascender
Curtiss XP-60A
Curtiss P-37
Douglas XB-42 Mixmaster
Douglas DC-8
Lockheed P-38 Lightning
North American A-36 Apache
North American F-82 Twin Mustang
North American P-51 Mustang
Potentially, anything with a V-1710 could be engineered to fit. Mustang and Kittyhawk are the obvious ones, of course.
Quote from: Rheged on May 12, 2023, 08:10:03 AMBack in about 1961 or 1962, a very much younger Rheged converted an Airfix Defiant into a single seater with a single "large tank-busting gun" under each wing and  rockets borrowed from another kit (I forget which....but they were jade green and might possibly have been from  a Heller Alize).  This was my first ever whiff.............but it was not a great success as I had not at that point learned the dark art of PSR.      Kit's current iteration of a Defiant flying tin-opener is a delight to see, and a cogent backstory with it!
It would have been good to see it!
Quote from: PR19_Kit on May 12, 2023, 08:17:13 AMABSOLUTELY old chap! One has to maintain one's standards after all!  :o
And not mix with the riff-raff :rolleyes:
Mark
Mark's workbench:
So, a bit before or about the time that I was born. :wacko:
Quote from: 2996 Victor on May 13, 2023, 05:49:09 AMThat opens up a raft of intriguing ideas (list of V-1710 aircraft pinched from Wiki):
Douglas DC-8
Replacing the engines in an XB-42 would easy in WhiffWorld, you can't see their shape anyway as they're buried inside the fuselage.  ;D
But surely the DC-8 is a mistake, the DC-8 was a four engined JET airliner?
Sabrecobra, Sabrehawk, and Sabrestang have a good ring to them.
2996 Victor
[/quote]
TBH I hadn't checked - sounds like good old Wiki! ;D
Mark
Mark's workbench:
Quote from: 2996 Victor on May 14, 2023, 11:31:22 AMthe DC-8 is a mistake, the DC-8 was a four engined JET airliner?
Only in the Real waorld!  :rolleyes:
2996 Victor
Mark's workbench:
Doug K
Really nice, as I've noted before I have an unhealthy Defiant obsession.....
