avatar_Gondor
AH-56C Cheyenne
Started by Gondor, November 06, 2021, 07:17:46 AM
This is quite a project but I'm sure it will be worth it!
A couple of update pictures
Just the fuselage, now with the new engine pack fitted
And here with the wings and canopy held in place by gravity and friction
More progress in the next two weeks I hope.
Nothing quite like gravity to give you a helping hand.
Except when it doesn't.................
The engines look very good on the hull.  :thumbsup:
AndrewF
This is shaping up nicely!
Minor setback while sanding the excess filler from the nose. The engine assembly came loose on the right hand side so once I finished the sanding I had to glue the join again except this time I added some support to keep everything in place.
Somewhat makeshift but it will do the job. Moar filler later but I think I will start filling in the area where the file is with plastic card so that area can be worked on.
Well that didn't work very well. The other side of the engines decided to come unstuck and the whole engine black wasn't centred so off it came. Bit of a blessing really as it has made it easier to add the filler around the engines.
A flat sheet of plastic card has been fitted to the top of the hole where the original engine was. This is what I should have done earlier as it will provide a nice stable platform for the engines once I have added filler to what I already have and built up some of the body work between the engines and cockpit.
There's paint on the model  ;D
Well ok, it is just to help show all the lumps and bumps due to the current state of the PSR at the moment
The top and bottom views don't look too bad at a glace, but.....
So lots to do and some of it is going to involve the use of power tools!  :wacko:
great shape.
Evolving very nicely
AeroplaneDriver
This thing is looking absolutely vicious.
Very little work if any getting done on this build so it is unlikly going to be finished by the end of the Group Build  :banghead:
Looking forward to this either way! How about a cool Desert Storm camo job!
