avatar_Tophe
P-38PPA push-pull asymmetric (finished page 2)
Started by Tophe, November 22, 2021, 04:08:34 AM
Thanks to Caveman's topic https://www.whatifmodellers.com/index.php?topic=49899.30 with an asymmetric one-engined P-38, I am going to build an even more crazy P-38: asymmetric also but push-pull with impossible weight centering and undercarriage:
= link http://www.kristofmeunier.fr/p38-pp-inspir.jpg
Here is what I have ordered today, to build it (arrival from China: maybe in 1 month) <_<
ericr
wah : one more typical challenge !  ;D
Thanks. I hope I will succeed (in building 1/144, not flying scale 1 as the crash would be sure): <_<
Uh, the P-38PPA is the leader of a whole family (of failures) but I will build a single one: ;)
= link http://www.kristofmeunier.fr/P38_persp_H_as.jpg
Here are the parts I am going to use, then what came from the first drops of glue: <_<
= link http://www.kristofmeunier.fr/IMG_5109_p38ppa.jpg
+ http://www.kristofmeunier.fr/IMG_5112_p38ppa.jpg
Caveman
It looks like that kit breaks down nicely for what you want to do with it. :thumbsup:
secretprojects forum migrant
Thanks! And thanks for the inspiration you gave through your own asymmetric Lightning at https://www.whatifmodellers.com/index.php?topic=49899.15
I have cut away/removed the turbo-room on the starboard wing. It may be simple if the starboard boom is not at the same place as the port boom but more rear, to avoid a lot of work. <_<
= link http://www.kristofmeunier.fr/IMG_5122_p38ppa.jpg
Starting to add putty on the "pusher boom" to replace the wing and tailplane-on-fin: <_<
= link http://www.kristofmeunier.fr/IMG_5123_p38ppa.jpg
Sanding has been done but this is not good enough a result (putty again is required):  :-\
= link http://www.kristofmeunier.fr/IMG_5131-p38ppa.jpg
Scotaidh
Thanks!
The model is finished, ready for painting.
What is on the tailplane is a top secret device, 2 copies of it <_<
= link http://www.kristofmeunier.fr/IMG_5142_p38ppa.jpg
Then painting the side above, just the black pen on canopy and propeller blades and it will be done: <_<
= link http://www.kristofmeunier.fr/IMG_5155_p38ppa.jpg
