What colour is "Cockpit Green"?
Started by rickshaw, January 01, 2022, 07:24:22 PM
As the title asks, what colour is RAF "Cockpit Green"?  I am building a WWII aircraft...
It's Aircraft Grey/Green BS381C 283 and lots of companies do a version of it or their "equivalent".
I use Xtracrylic or Hataka nowadays
Quote from: rickshaw on January 01, 2022, 07:24:22 PM
Humbrol no 78, as a start for your trawling of conversion charts.  ;)
Modelmaster also did the tone (#2062).
I bought what Tamiya label as Cockpit Green (XF71).  It's nice shade, which i'll use on most aircraft, but investigation did reveal that it is apparently specific to one japanese manufacturer only.  Not that I care.
As an aside; my Dad told me that the Lancasters he worked inside of, were completely primed with Cockpit Green. And that it had a particular smell to it which wasn't unpleasant. Not like the interiors of a few crashed German aircraft which he explored around out of curiosity, he said their primer smell was really horrible.
It is said that in 1948, Rover boss Maurice Wilks bought remaindered stocks of RAF cockpit green to use as cheap paint on the early Landrovers.
To quote the childrens' author Joan Aiken  "  Is this a true tale.......well as to that I cannot tell you..."
but I'd like to believe it!!
dogsbody
#7
Here is a card I made, showing the different paints that I have, that have been used be other modellers on other forums.
with a uniform to wear,
a fast aeroplane to fly,
and something to shoot at?"
That's nice Chris  :thumbsup:
Of course lots of things can affect how a colour looks even if the same colour is used and we use these affects ourselves. Different shades of grey on different panels prior to spraying over them with the required colour will produce a tonal difference between panels so whether paint is applied directly onto a material, the type of material, different primers if used or another colour and of course the pain manufacturer or even the batch of paint will have an effect.
So basically you pick what you think looks right and go with it unless you have a paint swatch from the real item you are basing your model on.
Thanks all.  Wonderful clues what I should be looking for!   :thumbsup:
Quote from: Rheged on January 02, 2022, 08:06:05 AM
I've heard that too - and I find it credible since Mk. I landrovers used a lot of surplus aircraft aluminum from WWII, so why not RAF paints, too?
There's another one I've heard, which goes "If it ain't true, it oughtta be!"  ;D
Quote from: Dizzyfugu on January 03, 2022, 01:57:31 AM
When the classic Defender went out of production five years ago, you could still order it painted in a similar tone - the Grasmere green.
This thread has reminded me of what I needed to add to my shopping list. Ran out of mine a while ago.
Quote from: The Rat on January 03, 2022, 09:23:50 AM
We aim to be of service Ratty  ;) ;D
