avatar_NARSES2
Republic P-43 Lancer
Started by NARSES2, January 17, 2022, 06:27:09 AM
Hit my first problem yesterday not caused by the poor instructions. So far the finesse and fit of the parts has been excellent  :thumbsup:, but yesterday I fitted, or tried to fit, the canopy and it wasn't anywhere near as good.
The canopy comes in three parts, not sure why as you can't fit it open, and all three parts are very thick and it's this thickness which impedes the ability to pose it open. The join between the middle and rear sections is not the best fit, although it's here that the thickness gives you some room to manoeuvre with a sanding stick. Anyway after some playing around with a sharp blade, needle file and wet and dry I've got the thing fitted. Just needs a little psr where it meets the rear fuselage now.
I've seen photos on line of finished 1/48 versions with open canopies, but I'm certain you couldn't pose the 1/72 version as such without vacforming/crash moulding a new centre section ?
Still be interesting to see what others make of it ? The general fit could easily be me, but I don't think so this time.
frank2056
I would be careful smash molding a new canopy - you don't want to crack or craze the clear plastic this far into the build!
Wouldnt be to much of a nightmare to make a new one from clear styrene but it does involve making a mould and a plug or see if theres a AM one out there ..ive found some replacement canopys for 72nd aircraft i didnt even know they made models of so your luck should be pretty good mate  ;D
Trying to thin a thick canopy is a massive job and in my case multiply pieces  :lol:
Quote from: zenrat on January 23, 2022, 03:23:16 AM
I think when I build mine the RAAF will routinely remove the sliding section and fly with open cockpits.
Quote from: frank2056 on March 28, 2022, 09:01:15 AM
I'm not going to, haven't for a very, very long time.  I'm just doing my best to integrate the existing one and I'm getting there.
Quote from: zenrat on March 29, 2022, 03:37:48 AM
It will help for sure, but the way Dora have moulded the canopy you will still have 3 parts to it even after you've cut the sliding section out. Unless of course the RAAF's version had a different sliding section ?  ;)
Meanwhile mine should start seeing paint in the next day or so
Painting completed, the Hataka paints behaved impeccably  :thumbsup: Need to get a couple of coats of Klear on it and then the transfers can go on.
and then: final pictures will be wellcome! :thumbsup:
Quote from: Tophe on April 03, 2022, 06:06:03 AM
As soon as it's finished Tophe  :thumbsup:
Main transfers are on  :thumbsup: Just need to figure out which of the stencils I'm going to bother with now.
Spent a few hours fitting the cat's cradle of an undercarriage. The parts are moulded really well, but some are tiny and way beyond my eyesight. Couple that with the poor instructions, have I mentioned them before ?  :rolleyes:, and it took far, far linger than I thought.
Anyway it's done now and she's standing on her own legs. Moving on to those final fiddly bits now and the we can hold the "topping off" ceremony and fit the prop.  :thumbsup:
Quote from: NARSES2 on April 09, 2022, 05:37:53 AM
I had never heard in all my life the word "linger" (and Google Translate explained it to me today).
Thanks teacher NARSES2! ;)
Nick
Quote from: Tophe on April 09, 2022, 07:51:35 AM
Linger. What one of his farts does. It lingers in the room for an evil length of time.  ;D
Quote from: Nick on April 10, 2022, 04:01:31 AM
Not sure about 'linger', more stalk, or haunt.
