Beardmore Aviation Ship
Started by Caveman, March 04, 2022, 02:41:02 PM
I can't see any now, & that's after I enlarge the image to full-screen! :unsure:
frank2056
The 1/700 Avro 504 came out great! How did you support it?
Caveman
Quote from: frank2056 on May 12, 2022, 09:25:09 AM
Nose up at 45 degrees. Supports along the trailing edges of the wings and around the tail and landing gear. I'm trying a second batch, nose down inverted. The first all had a bit of warping on the wings and they have a noticeable taper.
secretprojects forum migrant
I'm not only jealous of the build, but even more so of your eyesight  ;)
Caveman
Short Folder 25mm wingspan...
Quote from: NARSES2 on May 14, 2022, 05:46:51 AM
Love that statement and one I can generally agree with
Caveman
frank2056
What resin are you using? Clear resins can have a slight bleed-through exposure. That may account for some of the warping. Still, really impressive results for 1/700.
Caveman
Quote from: frank2056 on May 15, 2022, 10:15:34 AM
I'm using a transparent resin. I had suspected that might well be the case. I had bought transparent resin so I could print canopies as well as the rest of the model. But I'm beginning to think that making vac form moulds would be a better bet for that feature. Once I'm out of transparent I'll move onto bog standard grey.
loupgarou
Quote from: Caveman on May 15, 2022, 12:27:47 PM
Vac form canopies in 1/700 ??  :o :o
Caveman
Quote from: loupgarou on May 15, 2022, 01:23:53 PM
No I meant in general. I've printed a few 1/72 aircraft on my FDM printer. I was hoping that with a clear resin I'd be able to get better quality prints and that would include canopies.
frank2056
I've tried printing transparencies with clear resin. The results were poor.
- The clear resin I was using (Anycubic clear) yellowed a bit after curing. There are other clear resins that yellow less, but...
- internal defects and even the occasional layer line will be visible, even after sanding and polishing.
- A canopy thin enough to minimize yellowing and internal artifacts may be too thin to survive the polishing/sanding required to make it transparent
Polymaker makes a clear filament that can be smoothed with alcohol. The main drawbacks are the cost and the surface durability.
I'm not saying that 3D printing a transparency with a resin printer is impossible - it's just that it would be far easier to print a master in an opaque resin, smooth it and vacuform the canopy from it.
That was my first thought until I read Caveman's reply  ;) ;D
Caveman
Actual ship progress in a ship topic...
Looking more like a ship! Got to work out what scheme I'm going to paint her in still. I think she's too late to be in the fetching white, yellow and black rig of the late 1800s. Ships boats and aircraft still to add.
