Vickers Swallow
Started by PR19_Kit, March 31, 2022, 02:40:26 PM
Lost Cosmonauts
Nicely fettled, just to note that all the wheels retract by folding forward so they sit at the rear of the bays (& it'll be a guaranteed tailsitter even then)
Thanks for that Alistair, I was wondering which way they sat.
I was also wondering about drilling up into the underside of the nose and pouring some 'Liquid Gravity' in there. It'd be totally invisible with a bit of PSR and some paint.
As filler, I highly recommend that stuff that goes off with a UV light pen.  Doesn't shrink, cures in seconds and will polish to a glass like finish.
Ah, I haven't got any of that, but I'll look out for some. Thanks Lee.  :thumbsup:
Try ebay.  There's loads on there, but all bar one come from China, so I boycotted them straight away.  I just use me Dad's.
Oh 1/144 scale ..that would make things rather tight ..yup go with just leaving em set at one position .
Like ya said Kit..1/72nd tho  ;D
I've often wondered if the asymmetric thrust would necessitate an almost immediate power-down on one engine on the opposite side. Would probably need to be automated.
What do they do on a B-52? The #1 and #8 engines are MILES apart on one of them.
Quote from: PR19_Kit on April 03, 2022, 01:19:02 PM
True, but there are 6 more in between, and none near the wingtips.
The B52 in flight flys just like any other multi engined plane..all 8 burning at the same speed..its massive flaps do all the turning and going up and down stuff ..have a wee look at the mesurements of this things tail ..its huge and with that pushes a heap of air when it moves.
Your Swallow will use whats called flaparons..does both jobs of the ailerons and flaps.
I had a RC flying wing which uses the same systems.
Flyer
Quote from: Wardukw-NZ on April 03, 2022, 05:06:07 PM
That would be it's rudder not flaps.
Elevons, elevator and ailerons, not flaperons.
Flaperons are used on a conventional aircraft layout where both ailerons droop to act as flaps for landing and/or takeoff but still move independently for roll control. I have R/C model's that use both set ups.
Yup rudder but i know for a fact B52 pilots will use their flaps to bank this thing like a figther and not the rudder..buggered if i know why..read it in a book about B52 crews during the Vietnam war.
Ya would think the rubber would help a heap ..but ive never flown a B52..just stood beside one .
Yeah ive still got a few RC birds myself and my go 2 transmitters both have a flaparon setting and now ive only got one plane which use it and its only a 6 channel.
Some days i seriously think of building another flying wing..it was 4.2 mtrs span and powered by 2 OS .80s..id look at electric today tho.
Lost Cosmonauts
Barnes Wallis ,as far as I know which is never very far, didn't intend to have flaperons or other conventional flying surfaces. Everything handled through tipping and turning of the engine mounts
Flyer
Quote from: Lost Cosmonauts on April 04, 2022, 12:17:38 AM
Sounds dodgy and dangerous. Forget about flying it HOTAS then I'd be flying it HOTAB, Hands On Throttle And Bangseat!
Flyer
Quote from: Wardukw-NZ on April 03, 2022, 11:36:51 PM
I have a several 2 strokes ranging from a Cox .049 up to a .91 boxed away that will probably never get used again, been all electric for at least the last 10 or so years myself.  :thumbsup:
