avatar_zenrat
Handley Page Harpy.
Started by zenrat, April 05, 2022, 04:08:50 AM
Quote from: nighthunter on May 09, 2022, 04:53:06 AM
And Tophe,
Let's not forget that even Yanks don't always get sarcasm, either. And some get grossly offended by it  :rolleyes: :o :banghead:
Uh, I was not laughing at someone, just understanding someone has far higher knowledge than me ;) <_<
nighthunter
Quote from: Tophe on May 09, 2022, 05:03:54 AM
And Tophe,
I know, my cousins, the Brits, Kiwis and 'Roos forgot about their American cousins who are also fluent in sarcasm, lol
Sarcasm IS the highest form of wit.
Quote from: zenrat on May 09, 2022, 05:44:32 AM
Very much so  :thumbsup:
Just wondering if the tails should be cantered outwards a tad ?
For practical reasons, I'd have them outboard of the exhausts - one engine fire and you'd lose half your control, and flying wings are very unstable to start with.
"Visit Scarfolk today!"
Quote from: The Wooksta! on May 09, 2022, 07:09:21 AM
Personally, I'd also move them further outboard. And at high angles of attack they would be completely blocked off the airstream through the wing body? Another idea: cut then in half and mount one piece above and the other below the wing? Could also be used as tail bumpers?
The leftovers remind me of a precursor if the TSR.2. IIRC there was a D.H. design that had a very Victor-ish fuselage, swept wings and a pair of engines in nacelles under the ings, plus a T-tail. Your rests could qualify for a 1:72 in this class, too!  :thumbsup:
Quote from: Dizzyfugu on May 09, 2022, 07:43:22 AM
It was the De Havilland submission to GOR.339.  Fuselage is nothing like a victor and is likely the DH117 (F155 submission) with the engines moved under the wings.
I know the one Dizzy refers to but a couple of hundred miles away from my Buttler book so can't comment on the project identity.
It has an almost airliner-style fuselage, low-set delta wing and IIRC four podded jets.
Lee is correct in saying that the fuselage isn't Victor-like, but there is a passing resemblance to the design in Fred's photo courtesy of the camera angle.
EDIT:  See HP99 drawing posted by Mossie at https://www.whatifmodellers.com/index.php?PHPSESSID=foub7bdpi3bfr0o177dpo0dkt3&topic=12733.15.  Not the delta I am looking for (as Obi Wan might say) but there's a slight resemblance to the Victor.
EDIT 2: Avro 721 is the one I'm thinking of, see https://www.secretprojects.co.uk/threads/b-126t-or-314-or-324-low-altitude-bomber-designs.34020/
Sanding, sanding, sanding, sanding, sanding...
Running low on wet'n'dry.
Note to self, consider sanding off raised detail before assembling model.
Ill send ya some Fred..ive got crap loads of wet n dry..everything from 60 to 2500 grit  ;D
Don't bother with wet and dry, get some flexible foam backed sanding pads, of the type you get in auto repair stores.  But get them via ebay as offcuts.  A few pounds or Aus Dollars should get you a small cushion size pack that will last a good ten years or so.  I've done that for the last few years.
I'd agree with Lee there, those pads are the business for getting rid of rivets, and for the heavy duty part of the dreaded PSR.
I still use small bits of wet-and-dry for getting into nooks and crannies where the pads won't reach, but otherwise it's pads every time for me.
I have some pads, which admittedly have seen better days.  Although worn out pads are great for a final polish.
I like to use a combination of sanding sticks, wet'n'dry (with and without a wooden block), and sanding pads.
Put on a guide coat of primer today.  Needs more filler and there is raised detail I missed.
I like Lee's idea about the off cuts as sanding pads aint cheap here (nothing is really) and i do use em on cars or trucks i work on here ..when there work these days  :lol:
The only issue ive got is that bloody mail thingy..takes so long to get stuff and im inpatient and theres the annoyance of it not turning up at all.
I do use my buggered pads for the same thing as Fred..great for finishing work..on both models and 1/1 scale stuff too  ;D
