avatar_NARSES2
The LHC Group Build - General Discussion
Started by NARSES2, May 24, 2022, 07:21:40 AM
Quote from: PR19_Kit on September 23, 2022, 10:35:32 AM'Donation bins' will be in place on the SIG stand at Telford.................  ;D
I'll keep an eye on it Kit  :angel:
I now need to start getting my brain around the next GB  :mellow:
Quote from: NARSES2 on September 24, 2022, 06:10:45 AMI now need to start getting my brain around the next GB  :mellow:
The designated Mods are all over it, Chris!
Logistics.  I'm ready to start.  Kit's on the shelf.  Got the transfers.
Can I get a start extension?   ;D
I had a feeling when I typed that someone would comment...
The shelf is where I keep some of the larger unbuilt models but even so I don't think there is room for you.
One day to go.  GB ends Midnight local time October 14th - That's the Midnight between October 14th and October 15th.  In order to be entered in the poll your work must be posted in the Finished Build thread before it is locked.
Leading Observer
Quote from: zenrat on October 13, 2022, 03:29:26 AMOne day to go.  GB ends Midnight local time October 14th - That's the Midnight between October 14th and October 15th.  In order to be entered in the poll your work must be posted in the Finished Build thread before it is locked.
Blimey, better get my a**e in gear
LO
Good luck to all of the entries,  unfortunately I didn't get to finish my build but it will be finished sometime soon.
That's yer lot, it's all done and dusted now.
This GB is DONE!
thundereagle1997
https://www.deviantart.com/armoredryukenshi1984/art/YF2Y-2-F-7A-Sea-Dart-diagram-954541451
We need more amphibious fighter aircraft designed to operate away from vulnerable airbases and also on water including the roughest seas
Quote from: thundereagle1997 on April 25, 2023, 05:00:00 PMhttps://www.deviantart.com/armoredryukenshi1984/art/YF2Y-2-F-7A-Sea-Dart-diagram-954541451
So which do you see this being based on - Lightning, Hunter, or Canberra?
thundereagle1997
#162
This January 1955 drawing illustrated a future F2Y concept that borrowed design elements from the F-106A as the original Sea-Dart shared design features with the F-102A. This variant was to have been powered via a single General Electric J-79 that was earmarked for the B-58A Hustler. Would the aviation world have been ready for a Mach 2 seaplane fighter? Yes but with some modifications such as close mounted canard foreplanes a bubble canopy a MIG-21 style tailplane a cranked arrow double delta wing with the wingtips cropped & replaced via AIM-9 rails & twin engines with the choice of J79-GE-J1Es  F414-EPEs or F110-GE-132s.
So, none of the above then.
Which begs the question why did you post your comment here?
Do you look at the threads you post in or do you just scatter your comments at random across the forum?
In future I think we should lock GB threads once they're done and dusted, as this one has been for the last SIX MONTHS!   :banghead:  :banghead:
