avatar_NARSES2
The LHC Group Build - General Discussion
Started by NARSES2, May 24, 2022, 07:21:40 AM
Quote from: ericr on June 09, 2022, 09:59:39 AM
Something rather Fairey FD3 about this one.  Just needs a pointy radome for it to be a closer match.
AeroplaneDriver
Quote from: kitbasher on June 10, 2022, 07:38:14 AM
I knew it reminded me of something.  Spot on.
I was thinking more F-111 but with a fixed wing?  Very tempted to have a go at that.
"Visit Scarfolk today!"
And it's about the same size too!  :o
Zero-Sen
Does a scifi Lightning complies with the GB rules?
( scale-o-rama : Lightning wings 1/100 + Cobra 1/72 )
Not part of the GB, but I've started cutting plastic on the BAC Flattening.
Quote from: Zero-Sen on June 13, 2022, 12:38:56 PM
I'm pretty sure it does, you'd be using parts of a Lightning, no matter what the scale, and that's enough to comply.
Fred?
Quote from: perttime on June 08, 2022, 11:58:34 PM
A Lightning fuselage could make a pretty good land speed record vehicle.
Shhh.
I have been planning one of these since the old LSR build.  I have the older Airfix kit but need to chop the belly tank out and still trying to decide what kind of wheels to put in the nose gear area.  I have some spats for the rear ones and debating on whether to adjust the stabs to hold them or just some struts.
I was going to call it White Lightning but I want to do it in British Racing Green.  Also need some sponsor decals for it.
Might go with something similar to this but maybe with BP as the fuel sponsor.
Quote from: PR19_Kit on June 13, 2022, 02:46:14 PM
Fred?
Absolutely.  It has parts from a LH or C kit and so qualifies.
Caveman
Quote from: Zero-Sen on June 09, 2022, 01:31:28 PM
Old Hunter ideas...
shaded version of the Hunter + Mirage2000B variant ...
May have to give this one a go!
secretprojects forum migrant
Something different --- mix & match bits between a Hunter and a Gripen. I did a comparison between them after reading about HS staff being loaned to SAAB which resulted in the Gripen. The two aircraft practically match one another for size ----
nighthunter
I have both Revell 1/144 & 1/72 Hunters as well as one or two 1/144 from Mark 1
As Hunters are my favorite UK fighter, I of course have plans for this GB, hoping to move them out of storage tomorrow
Quote from: kitnut617 on June 15, 2022, 08:37:59 AM
Something I would never have realised until you mentioned it. But then I've never built a Gripen and am fairly sure neither have I built a Hunter ? Mind you I will for this GB, or I'll build a Lightning or Canberra which I know that I've not built before. Moi ; Heretic ? Never  :angel:
