Supermarine Spitfire ASR.Mk.14
Started by Knightflyer, June 04, 2022, 09:50:43 AM
royabulgaf
Thanks for all the help!  I took a look at the ASR Lancs, but if and when I do one I'll probably use one of the all yellow Whirlwind schemes.
Knightflyer
Quote from: royabulgaf on June 13, 2022, 07:13:19 PM
Of course in some universes - the Royal Navy (and RAF) continue to use amphibious flying boats - which gives you this
https://www.whatifmodellers.com/index.php?topic=41223.msg702970#msg702970
and here I am with an Amodel 1/144 Grumman Albatross in my stash as well, methinks the story will continue!  ;D
Oh to be whiffing again :-(
Quote from: Knightflyer on June 13, 2022, 11:51:38 PM
:thumbsup: :thumbsup: :thumbsup:
Wurgerman
An all yellow Lanc would look fantastic !
Quote from: Wurgerman on June 14, 2022, 04:52:12 AM
Ericr's probably already done one, with Do-X wings of course.  ;)
Knightflyer
Well the Albatross would be in service in the early 1950's to replace Sea Otters / Walruses, so I 'see' Coastal Command camo over white under surfaces, but a Hi-Vis yellow or yellow with red certainly appeals (or camo with Hi-Vis panels of either yellow or red?)
