avatar_Gondor
A Shocking Italian!
Started by Gondor, July 02, 2022, 02:09:16 PM
This is going to be a simple and straight forward build of an Airfix F.6 Lightning, put into Italian markings with the addition of under wing pylons as per the Mk.53 versions.
The kit is from the stash of Airfix Lightnings, to the left of where I sit at the computer. This kit was not allocated to any project although I had thought of this as a possible build anyway so with the Group Build it's the ideal time to do so.
The proposal for Italian Lightnings was from 1965, which may predate the Saudi "Magic Carpet" deal and additional lethality.
"Visit Scarfolk today!"
Quote from: The Wooksta! on July 02, 2022, 03:27:53 PM
I can always say it was a mid life upgrade for outer pylons otherwise it's just a straight build.
You mean a ground attack version?
Other than a couple of parts being glued together nothing has been done with this as I was waiting for an eduard zoom set to arrive which it now has. Next thing will be getting time as the cat is being a bit clingy after being missing for ten weeks.
The cat was missing for ten weeks? And it came home again? Or was it you who was missing?
Quote from: kerick on August 02, 2022, 02:19:58 PM
The Cat, who was living up to his name of Spot, as in "Spot the cat" only I couldn't for ten weeks as he wasn't around. Now it's "Spot the cat" so I don't trip over him especially if I go into the kitchen as that is where his treats are and he thinks that every time I go in there he should get treats even if I am making a cuppa.
I've known/heard of cats who had two or three "owners", or people who thought they were the owner. Although 10 weeks is a fair old time.
Well, we could go with the old saw that "Cats don't have owners, they have staff!" ;D ;)
Taken a while ago but you can see why he is difficult to Spot
loupgarou
Yes, you should really change the flooring... ;D
Quote from: loupgarou on August 03, 2022, 10:55:08 AM
In the picture he was laying on the path outside my door, but you get the idea. Almost as bad on the Dark Green carpet in the hall too  :rolleyes:
Spray him dayglo. I know you have the paint as well as the air gun already..   ;)
The Ex jokingly wanted to paint a while stripe down his back  :rolleyes:
