avatar_zenrat
Martin B28½ Canberra - Finished pics Pg 7.
Started by zenrat, July 24, 2022, 04:36:30 AM
Progress.
Canberra WIP 20-09-22 by Fred Maillardet, on Flickr
She's going to be very interesting when finished. :thumbsup:
Another coat of topside grey today.
Stock (1/144) undercarriage will be too short as they will put the intakes too close to the ground.  Having failed to grout out longer bays before I put it altogether I shall be rummaging in my bag of undercarriages and creating something pseudo telescopic.
All you need is a hole big enough for the undercarriage leg and a small door the same size as the hole. You only then need to mark out where the other undercarriage doors are on the underside and say then only open to the the undercarriage in or out of the undercarriage bays  ;D
Quote from: Gondor on September 22, 2022, 05:48:26 AMAll you need is a hole big enough for the undercarriage leg and a small door the same size as the hole. You only then need to mark out where the other undercarriage doors are on the underside and say then only open to the the undercarriage in or out of the undercarriage bays  ;D
Excellent thinking Gondor.  That will work perfectly.  I just have to ensure I scribe accurately.
Thank you.
Quote from: zenrat on September 22, 2022, 06:45:23 AM
Thank you.
Use a card cut-out of the shape you want to scribe, flip it over for the second side, nice and simple  :thumbsup:
I stuck to straight lines and used Dymo tape as a guide.
Thanks again for the suggestion.
Camo paint and underside look ready for some clear now.
Quote from: zenrat on September 23, 2022, 06:40:18 AMI stuck to straight lines and used Dymo tape as a guide.
Your welcome
Gloss clear today.
Tomorrow I shall find out if the A Model transfers want to play ball.
Stickers are on.
Canberra WIP 27-09-2022 by Fred Maillardet, on Flickr
Thanks Mr P.
I think i've finally got enough weight into it.  I had to fill the fronts of the nacelles and then drill into the nose gear bay and poke heavy glue into the void behind the pilots seat.
Quote from: zenrat on September 27, 2022, 03:29:08 AMStickers are on.
And they bring her completely to life  :thumbsup:
How did they behave ?
