avatar_Tophe
Bouton-Paul P.99C (completed page 1)
Started by Tophe, July 28, 2022, 05:08:59 AM
When I repaired my broken P-38W 1/72 (https://www.whatifmodellers.com/index.php?topic=50711.0 ), I did not install back the push-pull group that I have found as miscellaneous broken parts:
= link http://www.kristofmeunier.fr/IMG_5797_d28.jpg
Its destination may be a Boulton-Paul P.99 (Unicraft Models 1/72) I built in 2018 as a glider or powered by mental force. Propellers and pistons may help.
Here are the receiver together with its future engines, that I will try to put on top of the fin: :unsure:
= link http://www.kristofmeunier.fr/IMG_5826_d129.jpg
With glue, waiting to dry, hoping this will be solid enough... :-\ ;)
= link http://www.kristofmeunier.fr/IMG_5828_d129.jpg
The basis was a single-sat pusher (P.99, never built scale 1, with booms from the wing, 1 engine, 1/72) that I whiffed into the P.99B of mine (with many passengers and booms from the pod, no engine, 1/100) and now I am making the P.99C (with many passengers, booms from the pod, 2 huge engines, 1/100).
Gluing was a success and not very fragile it seemed but I decided to add 2 little supports on the top of the fin, to prevent self breaking if a window is open with some wind going in the room... :-\ ;)
= link http://www.kristofmeunier.fr/IMG_5829_d29.jpg
+ http://www.kristofmeunier.fr/IMG_5831_d29.jpg
So bizarre it's quite likely that B-P really did it!  :thumbsup:
Thanks a lot!
The most crazy part was from P.99 to P.99B in 2018 at https://www.whatifmodellers.com/index.php/topic,45059.0.html
Here, from P.99B to P.99C, I am just adding crazily big engines (1/72nd ones on 1/100th model)... :unsure: :-\ ;D
Mad!  :thumbsup:  You've excelled yourself there, Tophe.
Here is the comparison between the true (but unbuilt scale 1) P.99 and my fantasy P.99C: ;)
= link http://www.kristofmeunier.fr/IMG_5846-d29-igr.jpg
On a shelf of mine, overcrowded with little sky blue models, only one is standing high now: the push-pull of the P.99C! ;) "this is the top!"
= link http://www.kristofmeunier.fr/IMG_5960_p99c.jpg
Robomog
Beautifully bonkers build  :thumbsup:
Nice one Tophe!
Mog
Now all has changed position, as the shelves are now mainly for books (my books but my wife's decision). The P.99C still is above all the others with its pair of engines, it is even touching the sky (the ceiling)... ;)
= link http://www.kristofmeunier.fr/IMG_6103_p99.jpg
