avatar_AeroplaneDriver
Airfix 1/48 Vampire-RAE Meteorological Research Flight. Completed
Started by AeroplaneDriver, August 26, 2022, 01:23:34 PM
AeroplaneDriver
Been lacking mojo lately.  Started this one several weeks ago but it's been untouched since.  Starting 5 (potentially 10) days off tomorrow so I'm hoping to get it finally finished.  Hopefully posting it here will motivate me.
I'm leaning towards an RAF Meteorological Flight aircraft with a big "Snoopy"-like nose boom.  Maybe some bits and bobs fitted for inflight icing research.  It's going to be. bit early for Raspberry Ripple so thinking maybe white/grey with some flourescent orange panels/surfaces.  I started it with the landing gear retracted so it'll be an inflight build.
Quote from: Tophe on August 26, 2022, 07:35:44 PMthanks: enriching the universe of twin-boomers! :thumbsup:  ;)
Uh, sorry there may be a misunderstanding: I do not mean I think the nose will have a double boom this way but: the Vampire is a twin-boomer concerning tail rear support, and this one may have a special nose (even if counting this as boom could make a triplex-boom layout, no more twin-boom perhaps).
AeroplaneDriver
Tophe, my plan is a nose somewhat similar to the red and white striped one on the RAF Hercules.  That was a Meteorological Research Flight aircraft for a long time in the RAF.  I'm going to keep to proportional to the Vampire but I think it will be an interesting look.
I saw that in detail at https://twitter.com/clark_aviation/status/1297473658064003072
and yes, it would be great on a Vampire, yes! :thumbsup:
comrade harps
Whatever.
Quote from: Tophe on August 26, 2022, 07:42:15 PMUh, sorry there may be a misunderstanding: I do not mean I think the nose will have a double boom this way but: the Vampire is a twin-boomer concerning tail rear support, and this one may have a special nose (even if counting this as boom could make a triplex-boom layout, no more twin-boom perhaps).
To explain better the puzzle in my brain (2 boom or 4 boom?) on a P-38 example rather than Vampire (2 boom or 3 boom): :unsure:
= link http://www.kristofmeunier.fr/P38_persp_L_af.jpg
Vampire, one of my favourites.  Not my usual scale, but I've been toying with the idea of getting one.
Precursor to the Gnat?  IIRC it carried gust response probes in the tiger striped booms.
https://www.airteamimages.com/bac-one-eleven_XP505_uk---royal-air-force_97406_large.html
Quote from: AeroplaneDriver on August 26, 2022, 08:01:49 PMTophe, my plan is a nose somewhat similar to the red and white striped one on the RAF Hercules.  That was a Meteorological Research Flight aircraft for a long time in the RAF.  I'm going to keep to proportional to the Vampire but I think it will be an interesting look.
Definitely! :thumbsup:
Considering the construction of the aircraft which the "pod" is made from plywood. There is very little structure forward of the cockpit except to hold the nose gear, perhaps have the probe/boom mounted on the side of the fuselage, say the right hand side with the level a little bit lower that the cockpit sill then you could name it "The Lancer" or something like that  :rolleyes:
There was a gun camera directly above the wheel bay in some marks, should be enough room for some compact kit.
I like the idea Nick ! Looking forward to seeing where it goes.
I like the Vampire..twin boom aircraft i like alot even tho i cant sit in one of these and yes i have tried  ;D
Looking forward to this Nick  :thumbsup:
I managed about a decade or so ago, not sure I'd fit now, it's pretty snug.  Climbed into the bombing position in a Canberra on the same day, it took me so long to get out they nearly shut the museum on me!
I've been thinking about a canard Vampire with the booms coming out the front of the wings.
