Land Rover Series 3 88"
Started by Devilfish, December 12, 2022, 10:30:18 PM
Devilfish
I built this a while ago, but never posted it on here.  When I was in the RAF, on my first posting at RAF West Raynham, we had a section Landy that was a SWB S3.  I thought I'd give it a go at recreating it.  Unfortunately, other than the rare and expensive Monogram 1/25 kit, I don't believe there are any injection moulded SWB kits available, so I started with the Italeri 109" 1/25 kit
Landy by Paul Carter, on Flickr
I chose this version because it had the right hardtop for what I was building.
A lot of research later, I marked up the body and started cutting...
20210417_225307 by Paul Carter, on Flickr
20210417_230444 by Paul Carter, on Flickr
2021-04-18_07-56-19 by Paul Carter, on Flickr
20210418_084051 by Paul Carter, on Flickr
20210418_084132 by Paul Carter, on Flickr
20210418_170555 by Paul Carter, on Flickr
2021-04-18_09-36-21 by Paul Carter, on Flickr
And the same for the roof, which thankfully wasn't as complicated...
20210418_175821 by Paul Carter, on Flickr
20210419_211634 by Paul Carter, on Flickr
20210419_211657 by Paul Carter, on Flickr
The chassis was obviously also shortened...
20210417_220407 by Paul Carter, on Flickr
2021-04-18_12-56-03 by Paul Carter, on Flickr
Rear seats made from Milliput, and the rear suitably "worn"
20210502_185755 by Paul Carter, on Flickr
Bumpers militarised
20210423_223905 by Paul Carter, on Flickr
20210503_123112 by Paul Carter, on Flickr
2021-05-03_07-18-04 by Paul Carter, on Flickr
And the finished article
20210504_221724 by Paul Carter, on Flickr
20210504_221730 by Paul Carter, on Flickr
20210504_221736 by Paul Carter, on Flickr
20210504_221751 by Paul Carter, on Flickr
20210504_221743 by Paul Carter, on Flickr
20210504_221757 by Paul Carter, on Flickr
Absolutely brilliant! (And the opposite way around from when LR built the 109" back in the the 1950's..)  ;D
What a super job you've made of that!  :thumbsup:
Keeping all those cuts parallel is a work of genius, well done.
Bloody nice cutting and shutting Paul  ;D
Surprised ya didn't go for the italeri 35th 109 landie but ill admit it is easier in 25th .
Yup a very nice bit of work ..funnily enough I'm going the opposite direction with a 35th landie very soon  :wacko:
Excellent build! :bow:  :bow:  :bow:
Gives me hope for reducing a couple of Toyota Landcruisers I have (Italeri 1/24 BJ44 & AK Interactive 1/35 FJ43) into hardtop FJ40s like the one I owned. :thumbsup:
Mine was similar to this but with a white grill cover & a bull-bar.
Devilfish
Quote from: Wardukw-NZ on December 13, 2022, 12:20:49 AMBloody nice cutting and shutting Paul  ;D
The 1/35 one doesn't have a hardtop.
I looked at the Revell 1/25 kit too, but being a 4 door, I thought it would be too much work.
Devilfish
Quote from: Old Wombat on December 13, 2022, 12:25:34 AMExcellent build! :bow:  :bow:  :bow:
I had to go on dozens of websites to find photos and diagrams of the bodywork and chassis, so I could figure out the differences.  I found a technical drawing of both chassis' with measurements, which I based a lot of the conversion on.
As you own the car you want to build, you can go out and have a look, which will save a lot of time.  All I can suggest is the old maxim "measure twice, cut once!" slowly and carefully
No, I owned it almost 40 years ago, so research is ongoing to assist me when the time comes to cut plastic. ;)
Excellent work.  Well done.  :thumbsup:  :thumbsup:
Only today I was thinking about doing similar to an Italeri 1/35.  No research though, just cut 21 scale inches from where it'll be easiest to hide the join.
That's a tremendous piece of workmanship  :thumbsup:  :thumbsup:
Joe C-P
This is a very nice piece of work.
63cpe
Excellent work! Absolutely believe able build.
I got, while doing military service, my driving license on a swb Landrover (diesel) in winter time. It had a soft top over the rear seats and plastic windows which fogged up very soon. Couldn't see anything in the rear view mirror. Comfort: it had none. Speed: it maxed out at 78 kilometers an hour. Quirks: the turn signal was on the dashboard and worked reciprocal. Other quirks: it was very well know in the Dutch army to snap off inner axles once the drive forgot to switch off 4wd once it was on normal roads.
 If I remember correct the engines in the Dutch army Laro's ( as they were affectionately known) were petrol engines converted to diesel as it was cheaper to run.
David aka 63CPE
Well done,  it brings back memories from my days in the T.A. Royal Engineers Searchlight Unit back in 1984.
Nice work! :thumbsup:
Um, as to the hard top in 1/35, I'm pretty sure Italeri have done one recently... academic now, but the info is there FWIW.
There were a couple of articles in the 1970s Military Modelling where they took the Tamiya Ambulance and SAS kits, cross-kitted and scratched and ended up with a regular LWB (or SWB) and a Shorland Armoured Car.
My first 1/35 conversions, and the SWB may yet get finished sometime soon...  :banghead:
