Which Hurricane Kit?
Started by rickshaw, December 22, 2022, 09:42:01 PM
Which Hurricane kit has rockets in it?
Pretty sure the old Airfix kit had rp's Brian -- Mind you, if it's just the rp's you're after, the Mosquito, Beaufighter, Typhoon had them too
The new Airfix Typhoon has 8. And it's fairly inexpensive.
As a side note, Pavla does/did some nice aftermarket 60 lbs RPGs for British aircraft; a set comes with eight of them, including the launch rails. Much better than many OOB options.
If all you're after is 60lb RP's and rails then I have loads going spare. I'd need to dig out some decent ones, rather than "old school" ones though.
I thought you wanted a Hurricane with RP's.
