avatar_NARSES2
My Stash Just Grew Again 2023
Started by NARSES2, December 31, 2022, 05:19:39 AM
Quote from: Wardukw on December 26, 2023, 10:29:11 AM
Quote from: NARSES2 on December 26, 2023, 05:53:53 AM
Quote from: Wardukw on December 25, 2023, 08:45:23 PMIt's a Hawker Tempest MK V float plane .
Now that's an interesting thought.  Single float plus outriggers or twin float ?
Single float with out riggers Chris...I'll probably have to lengthen the Zeros float as im pretty sure the Tempest is bigger than the zero  :wacko:
Gonna have to widen it to mes thinking 🤔.  ;D
Lengthen, widen and deepen a lot, you'd basically have to double the volume. Even the float from an N1K1 Kyofu would be too small.
Empty weights:
A6M2-N, 4,235 lbs
Tempest V, 9,000 lbs
N1K1, 6,067 lbs
Two more 1/72 kits from eBay;
Airfix Boeing UH-46 Sea Knight with Swedish decals and the larger sponsors
Boeing V-22 Osprey
Quote from: jcf on December 27, 2023, 12:10:00 PM
Single float  out riggers Chris...I'll probably have to lengthen the Zeros float as im pretty sure the Tempest is bigger than the zero  :wacko:
Empty weights:
A6M2-N, 4,235 lbs
N1K1, 6,067 lbs
Jon mate ..im liking this one 👌 👍
Building from a existing shape makes life far easier..im gonna try and build a float from scratch..no guarantees tho 😆
Quote from: Wardukw on December 27, 2023, 08:11:28 PM
Empty weights:
A6M2-N, 4,235 lbs
N1K1, 6,067 lbs
If I was going to try to scratch build a float i'd try to find a downloadable paper model I could re-scale to give me the shapes I needed.
Final score on birthday/xmas stash additions is as follows;
Hobby Boss 1/48 Pzkpfw iv Ausf F2.
AMT (ex Lindberg) 1/25 1967 Oldsmobile Cutlass 442.
AFV Club F-5E ROCAF Tiger II Eggplanes (two in the box).
Revell (ex Monogram) 1/24 1972 Plymouth GTX (Fast & Furious boxing).
Black Dog 1/72 PT Boat Accessories set for Revell kit.
Arrived today and quite quickly all things considered, Modelsvit Suchoi S-32 MK Hybrid. This, when eventually built will go with my Nicaraguan cartel air force, and be a sort of double wiff, as it didn't make it into service, and the cartel airforce is non existent too. Also ordered 2 other kits, K.P. SU-17/22 UM and RS models Messerschmitt P 1107.
I weakened & bought a small batch of small things as my final purchase for 2023 (which will be the first parcel received in 2024);
2 x DEF Model 1/35 British Scout car Ferret Mk.2 Sagged Wheel set for Airfix kits (DEF-DW35167) - Why 2 sets when I don't even have the Ferret to put them on? Good question! Guess I'll have to buy 2 Ferrets when they become available again to find out.
1 x DEF Model 1/35 US M38A1 1/4t Utility Truck Sagged Wheels Set for AFV Club AF35S17/AF35S19 [5 wheels] (DEF-DW35075) - I have about 4 or 5 kits based on the M-38 & these are better than the rubber tyres that they come with.
1 x DEF Model 1/35 Modern Female Photographer - Diana (DEF-DF35017) - Another journalist/reporter figure to find a place for in a diorama.
1 x HS Models 1/350 7m Rigid Infantable Boat (HSM-U350085S) - It really should be Rigid Hull Inflatable Boat [RHIB]; to accessorise my modern 1/350 ships.
1 x HS Models 1/350 11m Naval Special Warfare RIB (HSM-U350087S) - Same as above.
1 x HS Models 1/350 11m Rigid Infantable Boat (HSM-U350086S) - Same as above.
Quote from: Old Wombat on December 28, 2023, 05:30:00 AM2 x DEF Model 1/35 British Scout car Ferret Mk.2 Sagged Wheel set for Airfix kits (DEF-DW35167) - Why 2 sets when I don't even have the Ferret to put them on? Good question! Guess I'll have to buy 2 Ferrets when they become available again to find out.
Completely logical  :angel:
Will save you ferreting about for them later  ;D  :rolleyes:
I just ordered a decal sheet off evil bay. JASDF F-4EJ in 1/72. Enough for two aircraft although the stenciling looks like enough for three. It's for the F-104 + Viggen. Maybe I'll get it painted by the time the sheet arrives from Hong Kong.
Just received direct from Airmodel Products
1 x 1/72 Airmodel AM-261 R4D-8
1 x 1/72 Airmodel AM-6045 Bf 109 E/F/G/K FuG Antennas
The last because the R4D-8 by itself was under their minimum order value.
I  was in Hereford Hobbycraft looking for something else entirely;  I found a few kit boxes that had been  crushed and reduced.  I ended up with an Academy 1/72 Spad that may well end up as RNAS  and a Star Wars (allegedly 1/51)  Snow Speeder  that could become a Royal Marine fast assault craft.  They only wanted £2 each for them and since all the box contents seemed OK  I'll take this as a win.
Quote from: PR19_Kit on December 28, 2023, 03:58:37 PM
Quote from: Gondor on December 28, 2023, 09:29:22 AMWill save you ferreting about for them later  ;D  :rolleyes:
Coat? Hat?
Not planning on going out so I don't need them right now  ;D   :angel:
Leading Observer
An unexpected Birthday present from my brother - the 1/72 Xtrakit Sea Vixen FAW 2/D3
LO
