Main Menu
avatar_Gondor
The Mule
Started by Gondor, January 06, 2023, 04:37:47 AM
Quote from: NARSES2 on October 17, 2023, 06:07:26 AM
Quote from: Wardukw on October 16, 2023, 04:51:31 PMFirst off I never use the cap..mine always has a .5mm piece of piano wire in the tube ..bent at the end ..the glue always flows but when I didn't do that I'd use a lighter to burn the blockage out.
Burns out very fast and doesn't set the rest of the glue on fire .
I remove the dispensing tube/needle and then hold it with pliers while I burn it clean.
Oh that works quite well and when the bottle is empty I rip out the tube and keep it..they come in quite handy  ;D
I have mentioned elsewhere that I remove the tube and hold it in pliers while burning the glue out of it over my gas cooker. Started using the wire recently and was supprised at the blockage which I drilled out as I could not be bothered to "toast the tube". I may have a go with the wire and drill on the second Contacta glue I have which for some reason has always appeared to be blocked  :unsure:
Finally got around to painting over the excess white, only taken three months  :rolleyes:
Parts of the fuselage roundels ended up comming off with all the palaver with the masking etc back last year but as I have a decent white to use now I will touch up the missing areas. Once that's dry I need to paint a blue band around the centre of the rear fuselage white band, that's going to be done free hand as I have confidence in using the new brushes I am using.
So progress!
Not the best but with the way masking had gone previously I had decided to go free hand
Happier with this side
than this side
This is 1/72 scale and it's never been intended for a competition either. Sitting in the middle of a table at a show it will be good enough, especially if I tidy it up a little as this was the first pass with the blue.
frank2056
Looks pretty realistic... These guys aren't using airbrushes or fancy masks:
Even the codes are rubbish on that Spitfire!  :o
Ah, maybe because they've been 'over painted' by the Stripe Crew?
frank2056
Maybe they wanted to see how strict the German judges were?
"And it's a 4.5 from the East German Judge! Oh, rotten luck Johnny!"
Even when they're painting markings 'properly', they can sometimes be pretty rough - the Squadron Signal book on the P-40 (I think) has a close up of yellow/black checkertail markings that could have benefited from using some masking tape!
The comment was 'Modellers take heart!'...
Got a bit of mojo today so had a go at improveing the stripes.
I did the rework today because there was a lack of colour density for some of the blue and I was sure that I could get the edges of the blue better in some places and I am sure that I have. It looks better, not perfect but better. Think I shall call that part done. I also touched up parts of the roundels and the fin where the white had either come off or looked too thin.
