avatar_Old Wombat
Re: Airvell 1/72 Avro Winchester B.I/B.III
Started by Old Wombat, February 14, 2023, 04:34:16 PM
My brain don't seem to work these days when it comes to descriptions..still not enough sleep 😴
Having a bloody hard time trying to visualise this Guy ..pics will turn up soon enough so I'll really see then 👍
That they will! :thumbsup:
Although masking is taking its time, it's better to get it right than rush it. ;)
I know what you mean about black being too black Guy. For something like the underside of a Lancaster I'd probably use Humbrol Coal Black or Xtracrylic RLM66 which I normally use for tyres.
Quote from: Old Wombat on March 31, 2023, 11:15:37 PMThat they will! :thumbsup:
Oh take as much time as you want matey ..masking can make or break a build and having seen your builds before of course I am seriously looking forward to it 😀
I'm still trying to decide what to do with my grand slam Lancaster I got in that amazing 5 plane score. 🤔
Quote from: Wardukw-NZ on April 01, 2023, 03:27:54 AMI'm still trying to decide what to do with my grand slam Lancaster I got in that amazing 5 plane score. 🤔
You could always paint it in the Tiger Force scheme & display it over an aerial photo (if you can find one) of Yamato (preferably in harbour). :wacko:
After all, they dropped Tallboys on Tirpitz & Yamato was that much bigger & more heavily armoured. ;D
By the way, almost finished the masking for Colour #2! :thumbsup:
Colour #2 is done! ;D
Just waiting for it to dry enough to remove the tape & see how much seepage there is. :angel:
Just so you can see that "stuff" is really happening, here's a couple of very current photo's;
They both look right, depending on the lighting.
A couple of minor things that need touching up but no bleeding under the tape. None! WIN! ;D
Two camo colours (& one other, still covered in tape) down, one to go ... but not tonight! ;)
Hope that helps with your visualisation, Phill! :thumbsup:
Love it matey 👍 😄.  This is gonna be so good 😀
Other than the wingtips the plan view looks like the Manchester  :thumbsup:
Thanks, gents! ;D
The fins & rudders are slightly different, too, but you can't see that from above; couldn't have it look too much like a Manchester, that would be cheating. ;)
When I've finished, I'll put up the dimensions for all 3 derivatives (Manchester, Lancaster & Mancaster) for comparison.  :thumbsup:
Just put the remnants of the fuselage & the wings of the 1/72 Airfix Typhoon IB together as a paint tester for Colour #3 &, I must say, it goes together very well. :thumbsup:
Somewhat disappointingly I've discovered that the "Blue Black" that I was going to use to lighten the "Camo Black" seems to eat into the plastic through a primer coat, even through a primer coat & Camo Black coat to give an acid etched appearance. I don't understand why because all the other external colours, including the Camo Black, are SMS colours & don't do that. :-\
Even a 20% Blue Black/80% Camo Black mix eats straight through. 40% BB / 60% CB gives the tone I was looking for but, of course, eats the plastic. :banghead:
I'll see how Tamiya NATO Black goes over the SMS paints (acrylic over lacquer can be problematic) because it's the closest colour to what I want but, if that doesn't work, I'll have to use the SMS Camo Black & hope that a grey oil wash lightens it a bit. :rolleyes:
Glad I was using a test piece & didn't put it straight onto the build! :angel:
From reading this mate it was a bloody good idea using a test piece. ..it sounds like that bad paint has a ton of thinner in it or acid 🤔
What ever it is it has bad bach written all over it ...best of luck with the Tamiya paint Guy .
