avatar_Old Wombat
Re: Airvell 1/72 Avro Winchester B.I/B.III
Started by Old Wombat, February 14, 2023, 04:34:16 PM
Gloss has gone over the top surfaces. :thumbsup:
I shall now go & do some [shudder] housework while it dries sufficiently before I turn it over. :-\
Gloss has, now, gone on the under surfaces. :thumbsup:
More housework while I wait for that to dry. :-\
Been glossing today too mate ..well at 3:30am so it's bone dry now  :thumbsup:
Also glossed the Strumpanther couple of hrs ago ..so won't touch that now till tomorrow.
Well, that was bloody irritating! :angry:
Whilst wiping off some oil washes I was trialling, to highlight the panel lines, the port side (left) tail plane just fell off. Sheared off flush with the join to the fuselage.  :banghead:  :banghead:  :banghead:
Luckily, I have brass rod & the bloody-mindedness to get this fixed ..... Tomorrow. I need to get some sleep, right now. :rolleyes:
CA gel, brass rod & Revell Contacta cement applied. All taped into position & hoping like crazy that this works! :angel:
That's a nuisance, hope it stays attached this time  :thumbsup:
You & me, both, mate!
I'll pop down to the modelling room, shortly, to take the tape off & see what the damage is. :-X
Thank the Gods this study desk is wood! ;)
Quote from: Old Wombat on April 11, 2023, 07:18:00 AMThank the Gods this study desk is wood! ;)
Amen to that  :thumbsup: I can always touch my head, straight out of the tree of knowledge  :angel:
Well, that appears to have worked ... So far. :angel:
I've also re-washed the underside, as the grey I used earlier was too light. This time I've used Dark Brown. Just waiting for it to dry a bit more before I rub it down to remove the excess (VERY carefully in some places :rolleyes: ).
Mate with all the work you're putting into this it's going to look amazing I'll bet   ;D
Hopefully. If things stop breaking. :angel:
OK, as said earlier, fixed now & seems to be holding. Re-did the wash with dark brown, as the grey I'd used was too light (also mentioned before), & this time the tail planes stayed on despite considerably more vigorous wiping. :thumbsup:
Unlikely to get back to the bench for about a week, family coming (including the grandson) & going to a niece's wedding on the weekend, but I'll try to find some time to take a couple of photo's.
OK, just a couple of pic's to show where I'm at;
Black is such a pain to wash but that's looking pretty damn good ..once Matt varnished it's should look even better 😉
Yeah, well, the dark brown was a good choice; light enough to be visible but dark enough not to blind you with glaring obviousness! :mellow:
The original grey looked like every panel join had been taped over with 2" masking tape. :banghead:
I gave it a wipe over with a cloth dampened with isopropyl alcohol, just before taking the photo's, & it seems to have cleaned off the oily residue quite nicely. :thumbsup:
Matt varnish will have to wait until next week, when the family all bugger off again; which should give any remaining oily residue time to dry off (I hope!).
Time wise you should be fine..the oils I use from Ammo dar within a week easy ..well 5 days ..couple of times the oils have been dry within a couple of hours but thats probably temp related and I do thin it down  so  it flows better.
