Main Menu
avatar_Leading Observer
Crusaders
Started by Leading Observer, February 17, 2023, 02:30:14 PM
Leading Observer
This group build finally gives me the reason to build at least one of the F8U-? I have in the stash :thumbsup:
LO
Not enough Crusaders around here... i'm sure this will be good!  :thumbsup:
Leading Observer
Found the kits, and ordered some extras and even have ideas for the paint schemes :mellow:
LO
So no Knights in the Middle East then?
The Poor Fellow-Soldiers of Christ and of the Temple of Solomon (Knights Templar) or the Order of Knights of the Hospital of Saint John of Jerusalem (Knights Hospitaller) evolved to fight the heathen Saracens in the 1950's? :unsure:
Could be an entry in that! :thumbsup:
But probably not mine. :rolleyes:
'Saders are always an option, esp. in non-US service.  :thumbsup:
Leading Observer
LO
Quote from: Old Wombat on February 19, 2023, 04:48:55 AMThe Poor Fellow-Soldiers of Christ and of the Temple of Solomon (Knights Templar) or the Order of Knights of the Hospital of Saint John of Jerusalem (Knights Hospitaller) evolved to fight the heathen Saracens in the 1950's? :unsure:
Alternate time line:  Following the end of WW2 Jewish survivors of the camps and refugees head to central Australia where a Zionist homeland had been set up before the war (this was an actual proposal).  Militant Christian Soldiers claiming descent from Crusaders, Templars etc gather under the cross of St John and attempt to carve a homeland for themselves based on Jerusalem...
Holy War GB anyone?
Damn!! ...a lovely pile there  ;D
AeroplaneDriver
Love the Crusader.  Had a good work buddy who retired a good while back who flew them in the Navy in Vietnam.  So many cool photos shared.  A classic Fighter.  Looking forward to this one.
Leading Observer
Quick question - anyone know if nose weights are required to stop the model being a tail sitter?
LO
LO mate I don't think so..ive had a couple of Corsair 2s and their landing is extremely close in design and they've never needed weights .
When loaded out the weight is closer to the front because the in board weapons mounts are pushing weight forward .
There's any easy test.  Tape the major components together then balance it on a pencil.  If the tipping point is behind the main gear, you'll need nose weight.
As Duky says, you should be okay as the Crusader has quite a long forward fuselage.  I'd especially check the Crusader III as resin kits as a slightly thicker bit here or there can change the weight distribution.
Leading Observer
Crusader III virtually finished - some small adjustments to be done and the wing fixed in position
LO
