Main Menu
avatar_NARSES2
Aegean Defender
Started by NARSES2, February 24, 2023, 03:07:46 AM
Right well here's a shot of how far I've got, plus it gives an idea of her size/bulk when compared to a Spitfire.
There's still at least a couple of rounds of psr to do and I do have to say that a lot of this is not the kit's fault, especially the wing/fuselage join. I an no longer the precision instrument I once was  :-\ , indeed have gone from a 6lb club hammer to a sledge, but we will persist.
Taken with my phone so forgive any "shake"
May save up and treat myself to one at Telford.
Yes, that's a BIG aeroplane for a fighter!  :thumbsup:
I've seen the real thing at the Solent Sky Museum and it TOWERS over everything else there apart from the Solent flying boat just across from it. The SRA/1 even makes the Sea Vixen parked underneath it look small.
When you look at that very clear pic..shake my arse..you do get the impression it's big but it don't look alot bigger than a P-47 D or M .
Then you read what Kit said about the Sea Vixen and that's changes to 😳😲
Big is freaking huge .
I've still got a Planet one tucked away and one is enough.
It's the sheer height of the SRA/1 that impresses you. Of course it had to be that tall to keep the intake clear of the spray etc. but it's awesome nonetheless. And the Sea Vixen is a pretty low aircraft too.
Getting up to the cockpit must have been a major issue. :(
really do like the SRA/1, also seen the monster at Southhampton on one of my UK museum jaunts. I have done the Planet Resin kit and that was nice enough, fairly benign build. Finished beastie is here
I also had a crack as somebody's Vacform version, which wasn't so easy, directly because of the height of the fuselage, getting some anti flex bulkheads in was a pill.
Quote from: buzzbomb on April 09, 2023, 04:07:36 PMFinished beastie is here
I remember that now  :thumbsup:
It is the height of the thing that makes it look so big, especially with how small the cockpit appears to be. Once settled on the water it probably looked more "normal" ?
Anyway some more sanding done, and putty applied. I'm down to using some Revell putty and I think it may have been in the drawer to long  :-\
More psr completed, but I've still some more to do. I'm seriously considering a "sharks mouth" should that be a whales ? for that huge hole of an intake.
A huge vicious shark with massive choppers Chris  :thumbsup:
Quote from: Wardukw-NZ on April 12, 2023, 01:27:24 PMA huge vicious shark with massive choppers Chris  :thumbsup:
Actually it would probably suit a more docile one  ;D
I actually checked I have some Milliput this morning, that's how bad one of the seams is looking  :-\
Quote from: NARSES2 on April 13, 2023, 05:57:13 AM
Woah that's not cool ..ya need the big putty it sounds like a canyon not a gap 🤔
Quote from: Wardukw-NZ on April 13, 2023, 12:33:30 PMWoah that's not cool ..ya need the big putty it sounds like a canyon not a gap 🤔
It's not so much a gap as the wing root joint leaves you with the wing being "higher" than the fuselage. Almost certainly my fault so I can't complain to much, but I need to blend them in to get a smooth transition.
We shall persevere and we will get there though  ;D
Quote from: NARSES2 on April 12, 2023, 07:22:37 AMMore psr completed, but I've still some more to do. I'm seriously considering a "sharks mouth" should that be a whales ? for that huge hole of an intake.
Whale Shark?
