avatar_Vulcan7
Triple Defence Vulcan
Started by Vulcan7, February 27, 2023, 09:22:31 AM
#15
Quote from: McColm on February 27, 2023, 05:13:59 PMOr your build could have a parasite fighter carried above the middle section for air defence.
Have to be a Gnat.
Is the ordnance going to be a variant of the Red Wasp?
The old fashioned Testers white works well and doesn't yellow if you add only one drop of blue to the bottle. Better if you use the lightest grey primer available.
Why not just use a automotive based white primer like VHT .covers extremely well and it holds acrylics great..I used VHT flak black primer for pretty much all my builds..never had a problem .
Devilfish
Never mind such "practicalities" such as fuel! I want to see the airstrip wide enough to take this beastie! :thumbsup:
Quote from: McColm on February 27, 2023, 12:24:45 PMHave you got any plans for the four spare wings?
Flying (X) wing?
Maybe vertical take take off with skis that are deployed for landing on water,  which would solve the problem of using a runway.
Vulcan7
Very many thanks for top advice on white paint  :thumbsup:
I was thinking X-wing Vulcan for the extra wings left over ( a bit more of a tricky build though, plus saving up for another vulcan :-\ )
I also tried a Tornado on the wing, (great minds think alike  ;D ) ...One each side of the central fuselage, they seem to fit with wings swept back.
Did not think about the airstrip problem, salt flats maybe?.... big floats might ruin the look?
What-if I used a new top secret super fuel that give twice the range? ;D
As for white. In the UK then good old Halfords Appliance White spray cans. I've even found their white primer's a pretty good finish, especially with a top coat of Klear  :thumbsup:
Vulcan7
Quote from: NARSES2 on February 28, 2023, 06:23:51 AMAs for white. In the UK then good old Halfords Appliance White spray cans. I've even found their white primer's a pretty good finish, especially with a top coat of Klear  :thumbsup:
:cheers: Great, Halfords sounds good , many thanks
Quote from: Vostoc7 on February 28, 2023, 09:25:11 AM
I'll give it a try as well.
Wonderful triple plane, thanks! :thumbsup:
Uh, maybe I prefer double, but with photo editing the triple can become double... I think I will ;)
Vulcan7
Quote from: Tophe on March 01, 2023, 08:09:17 AMWonderful triple plane, thanks! :thumbsup:
 :cheers:  double does look good, but I cant run to a double & a triple so I plumped for a triple  ;D (feel free to photoshop away  :thumbsup: )
Thanks!
And I fully approve your triple, of course! ;)
Robomog
This is messing with my head  :o
But in a good way  ;D
My attention you has it !  :thumbsup:
Mog
Vulcan7
 :cheers: Mog
Just need to buy some filler & the paint......
You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
ps I usually never have undercarriage down so I have lots spare if anyone ever needs some?
