avatar_Dizzyfugu
DONE @p.5 +++ Republic F-96B 'Thunderguard', USAF 325th FIS, 1959
Started by Dizzyfugu, March 07, 2023, 11:57:37 PM
Still an early placeholder, but I have eventually found a suitable kit in The Stashâ„¢ for an eligible project for this GB. MB-1 Genie carriers seem to be quite popular this eason, so I will throw in another one: the Republic F-96B, an all-weather interceptor based on the (Italeri) RF-84G kit, as a replacement for the F-94 Starfire and an eventual stopgap for the delayed F-101B Voodoo in the late Fifties.
Stay tuned.  :mellow:
Nothing new here, yet. Was quite busy (again) recently, and just lacked mojo to start.  :-\
Quote from: Dizzyfugu on March 07, 2023, 11:57:37 PMthe Republic F-96B, an all-weather interceptor based on the (Italeri) RF-84G kit,
What are the expected modifications from RG-84G into F-96B? :unsure:
It seems our friend here TomZ already tried to build a F-96, see https://www.airwar1946.nl/whif/L46-F96.htm <_<
Nothing new here, try to stir my mojo with a mecha build, so it's still uncertain ETA.  :-\
Plan for the F-96B is to modify the nose with a radome, plus potentially a tandem cockpit for pilot and WSO, with a new canopy and a suitable cockpit tub.
Armament will only consist of missiles, probably two Genies and two or four Falcons under the outer wings. Rear fuslage/tailpipe might also be modified widened behind the air brakes for an afterburner engine. Plan is to make this thing supersonic., filling a gap between tze F-94 and the F-101B.
Paint scheme yet uncertain; classic USAF NMF or ADC Grey, maybe an ANG unit, with some bright color details.
Quote from: Dizzyfugu on March 31, 2023, 01:28:06 AMNothing new here, try to stir my mojo with a mecha build, so it's still uncertain ETA.  :-\
This is slipping right into my main interest period and technology focus. Looking forward to it!
It*'s quite hard to squeeze this aircraft into the Fifties time frame, but it should have entered service around '58 or '59 - to be quickly superseded by Mach 2 designs.  :wacko:
This thread has been quiet for a while, but I'll try to tackle this project soon so that I have at least one submission for this GB.
Good news! Things started moving yesterday, and since I had some weeks to think about the project and its many modifications, progress was very good.
First thing I tackled was the different tail section, to simulate an afterburner version of the engine with a bigger diameter and nozzle. I eventually found a good implant in the rear section of an Italeri B-66 engine nacelle, which had to be narrowed through wegde-shaped cutouts in their spinal area to match the F-84 fuselage right behind the air brakes, as planned. It's also a bit longer now, and I eventually implanted a different, wider nozzle (IIRC a leftover piece from a horrible Nakotne MiG-29 - stay away from this *shudder*). It still has to be fused with the F-84 fuselage, though.
1:72 Republic F-96B 'Thunderguard'; USAF, late Fifties (What-if/modified Italeri kit) - WiP
by Dizzyfugu, on Flickr
This was also modified, to accept a tandem cockpit for an additional WSO in the rear seat under a new/extended canopy. The latter as well as the cockpit tub with most of the interior come from a Heller T-33, and have already mounted into the cockpit opening. For the new strutless canopy, which is almost perfect in length and width, I can use the original F-84 opeing, I just had to cut the rear windows away and bring the fuselage on an even level with styrene strips. Looks very promising so far, and the rest of the T-33 might be converted into an F-80E later (with Saab 29 wings and a single-seat cockpit), as another GB submission.  :wacko:
The nose section is also already under modification. The camera windows were closed and a pointed radome (IIRC it's the tail cone from a Matchbox Buccaneer!) stuck to the original front- I also try to make the flat camera window areas disappear under putty, so that the nose become round all around and reminds more of the F-105 than the RF-84G.
From the Thunderchief I also adopted the idea of swept air intakes - quite easy to realize with the Italeri Thunderflash, and I will add scrathed splitter plates later for a more convincing, supersonic look.
One area that is still open is the fin - I am not certain if I will stick with the original one, as it appears quiet small for this enlarged aircraft. I have an alternative at hand, though, but I will wait until the fuselage is complete and mated with the wings to make a decision.
Yes, thank you! In the meantime, pics have been added above, and the fuselage has been completed. Man, is this thing ugly...  :unsure:
Lots of PSR ahead, but you can already recognize the idea of the "missing link" between the F-84F and the F-105?
