avatar_Old Wombat
1/35 Ukrainian Merkava IV (Academy)
Started by Old Wombat, May 22, 2023, 01:09:23 AM
That looks rather nice (Up for the understatement of the year in next years Whiffies  ;) )
Thank you very much, gentlemen! :bow:  :bow:
Happy coincidence - the Ukrainian BDU digi-cam decals arrived today! :thumbsup:  :thumbsup:
Camo'ed the TC's tanker coveralls from the bottom of the body armour down - because it won't be seen & is, therefore, the perfect practice area. ;)
I'm glad I paid attention to the tips that Ramba (over on BtS) gave out about putting camo decals on figures because, even though I did, I still had some small(ish) issues. :rolleyes:
Still, I've learned a bit - mostly relating to how stiff & fragile the Breeze Decals are until they've soaked up a LOT of Micro Sol. :blink:
Overall, though, still quite happy with this first effort. Hopefully the important upper parts will go a bit better. :thumbsup:
#183
Quote from: Old Wombat on August 07, 2023, 08:01:51 PMCamo'ed the TC's tanker coveralls from the bottom of the body armour down - because it won't be seen & is, therefore, the perfect practice area. ;)
One thing is certain..camo decals for figures do not like me at all..no matter what I do including youtube vids my luck with this is zero ...so I'll just have to do it by hand  :o
Also it's been said on this site before ..where's the proof ?? 😁😈
Camo decals are a slow process, in that I have to do one patch then let it settle & dry before doing the next - & it can take a few hours for all the Micro Sol to dry.
Having been looking at the tank, itself, I think the weathering is done as is, any more would be too much.
So, next will be "mudding" &, maybe, the base/dio, but that will need me to be able to sit down at it for several hours uninterrupted, which may not happen for a little while.
In the meantime, onwards & upwards with the TC! :thumbsup:
I'm starting to get impatient with this Guy but slowly getting that under control   ;D
Quote from: Wardukw on August 08, 2023, 09:07:03 PMI'm starting to get impatient with this Guy but slowly getting that under control   ;D
Patience, young padawan! ;D
At the moment all I can say for how it's going is "I'm glad I'm using a digi-cam, where most of my faults are camouflaged by the camouflage!" :-\
This is, obviously, primarily a side-effect of my inexperience using the things but may, also, be something to do with this brand of decal; the body armour decals may indicate if this is so, as they're a different brand (but are also Ukrainian),
Time will tell! ;)
Quote from: Old Wombat on August 09, 2023, 08:32:07 AM
Time will tell! ;)
I had 3 sheets of uniform camo decals from Trumpeter..brand new..totally fell to bits and stiff are printing paper..utterly useless..Mocro set and sol wouldn't do a thing with em ..since then I haven't really bothered .
A photo for the impatient people (person) ;) ;
Click For Bigger View (CFBV)
Hahaha 😀 😆 no name mentioned 🤣
He looks awesome mate...really looks the bis 👍👍
Very nice work with decals 😊
No names were used to protect the guilty. :wacko:
Well, it turns out that's the easier sheet to deal with (Breeze Decals).
The Print Scale decals are even thinner, & more fragile, & take longer to come off the backing, although it appears that if I use Humbrol DecalFix to start with, then use the Microscale products it seems to hold together a little better.
With a larger pattern I think it would be much more difficult to hide the errors that I've made but the biggest difference comes from the printers & how they've printed the decals, & (I assume) with what type of ink.
Still, even with the stuff-ups, looked at from 12" to 8" away the decals still look good; it's only at 4" with a magnifier that you can see most of the repairs, & even some of those you need to know where they are & really look for them.
Quote from: Old Wombat on August 09, 2023, 07:54:36 PM...looked at from 12" to 8" away the decals still look good; it's only at 4" with a magnifier that you can see most of the repairs, & even some of those you need to know where they are & really look for them.
Stop looking so close is something I have to frequently remind myself of.  Especially with PSR.
Little chap looks good  :thumbsup:
Quote from: zenrat on August 10, 2023, 03:39:52 AM
I take my glasses off  :angel:
It's that classic the more you look the more you find sort of deals and in most cases..it's a crappy deal so  I now work with this system...if I  can see it but you can't see it then it's not there  ;D
My theory is: If I can minimise the number of faults I can see at 4" under magnification, the less likely anyone is to see them at 12".
Anyway, more photo's of the TC;
CFBV
He'll be getting a thin gloss coat tonight &, probably, some oil washes.
Then tomorrow I'll hit him with a matt coat & some dry brushing, followed by fitting the final pieces (mic & binoculars) & another matt coat.
After that he should be done!
Then it's back to the main event! ;)
