avatar_Weaver
Rotary-engined ground vehicles
Started by Weaver, May 29, 2023, 04:08:25 PM
Does anyone know of any example of a ground vehicle powered by a rotary engine, that is to say, the kind of spinning engine found on some WWI fighters, not a Wankel rotary?
The only ones I know of are a handful of obscure motorbikes (one called the Megola) which used such an engine inside one of the wheels, and the Adams-Farwell car, which used horizontally mounted 3 or 5 cylinder engines.
Quote from: Weaver on May 29, 2023, 04:08:25 PMDoes anyone know of any example of a ground vehicle powered by a rotary engine, that is to say, the kind of spinning engine found on some WWI fighters, not a Wankel rotary?
Not that I know of.  I do know a Lemons racing team stuffed a Kinner 5 cylinder radial in a Toyota MR2
Sounds like it's time to build a whiff of one!
killnoizer
In fact I am on that project  :wub:
Got a dozen rotary engines left over from my builds  :thumbsup:
                     ~ π ~
VDPM Hannover / Germany
Imagine the torque reaction when you blipped the throttle with the car in neutral.   :wacko:
Quote from: zenrat on May 30, 2023, 04:08:55 AMImagine the torque reaction when you blipped the throttle with the car in neutral.   :wacko:
With the crankshaft vertical take it to an icy parking lot and rev the throttle to see if it spins in place!
The sole surviving Adams-Farwell rotary-engined car demonstrated running:
The exact opposite of Colin Chapman's 'Simplicate and add lightness' philosophy!
'Complicate and ad heaviness'!!!
I've seen that car at the Harrah Museum, but didn't realise what I was looking at as I only looked at the front.  :banghead:  :banghead:
Leading Observer
Fit it to an afv - didn't some Shermans have a radial engine?
LO
Quote from: Leading Observer on May 30, 2023, 09:12:34 AMFit it to an afv - didn't some Shermans have a radial engine?
Correct!!  Some had a Wright RD 1820  9 cylinder diesel radial  and others a Continental R975-C1 or -C4 9 cylinder radial petrol engine.
Yes, but that's not a rotary, the cylinders stand still.
A rotary of sorts as the 3-cylinder radial engines, plural, are mounted directly to the non-steering front wheels:
Rohrbach concept
More on the Adams-Farwell at Douglas Self's Museum of RetroTechnology:
Adams-Farwell
killnoizer
Quote from: Rheged on May 30, 2023, 09:26:20 AM
Oh , THAT's a difference I am also ignored . :wub:
                     ~ π ~
Quote from: jcf on May 30, 2023, 10:35:31 AMA rotary of sorts as the 3-cylinder radial engines, plural, are mounted directly to the non-steering front wheels:
It steers from the rear wheel?  :o  :-\
Be afraid, be VERY afraid!
