Main Menu
avatar_mat
Republic P-47T Turbobolt
Started by mat, June 14, 2023, 12:00:09 AM
I'll be doing the same thing to the Lighting shortly and I'm scared 😱 😬
I'm impressed by your body work  :thumbsup:
If I have to remove lots of putty or epoxie filler I resort to 80 grit until I get close. Then 220 then 400.
Quote from: kerick on July 26, 2023, 08:03:21 AMIf I have to remove lots of putty or epoxie filler I resort to 80 grit until I get close. Then 220 then 400.
Pretty much the same Ken here ..I just do it with water...wet sanding removes putty and epoxy very quickly and it don't bugger you sand paper much at all  ;D
frank2056
Mat's build and Phill's comment just put an evil thought in my head - the "Super TurboBolt" - put two coaxial jet engines vertically in a P-47 fuselage. Like a proto Lightning (although I think there was an early Russian jet with a similar configuration)
Vulcan7
mat
The fairing for the tailwheel have been added. Time to start the assambly.
mat
Wings on and more PSR ahead. Its time to divert some thoughts at paint and decals.
Now we can see where this is going  :thumbsup:
Quote from: NARSES2 on July 28, 2023, 06:05:38 AMNow we can see where this is going  :thumbsup:
And it is good! :thumbsup:
[I hope it's got BIG drop tanks! :o ]
Looking good - that big nose intake is reminiscent of the Westland W.36 'Jet Wyvern'.
mat
Quote from: Old Wombat on July 28, 2023, 08:50:34 AM
It gonna need some big droptanks with such a thirsty engine  :o
