avatar_Vulcan7
Jaguar 100 Flying Jet • FIN •
Started by Vulcan7, June 24, 2023, 09:25:53 AM
Yep, having one all over colour really pulls it all together.
Bravo.   :thumbsup:
ericr
 :o  ;D  :thumbsup:  :thumbsup:  :thumbsup:
impressive combination / mashup !
Quote from: zenrat on July 11, 2023, 04:44:53 AMYep, having one all over colour really pulls it all together.
It does, doesn't it  :thumbsup:  :thumbsup:
I couldn't tell where this was going at first but bit really came out well.
I'm sure Sir William would have been pleased.  ;D
Vulcan7
very many thanks for the kind comments folks  :cheers:  I still need to get some kind of sanding dremel to improve the finish  :rolleyes:  ;D
more pics & hovercraft option.......
Nope ..no Dremel ..by hand ..use car wax ..like Turtle or similar..alot of rubbing with clean very soft rags..you'll be amazed at the end result..a Dremel can spin to fast and eat the paint or heat up the plastic even with its polishing pads..ask me how I know  :banghead:
Vulcan7
Quote from: Wardukw on July 12, 2023, 12:10:38 PMNope ..no Dremel ..by hand ..use car wax ..like Turtle or similar..alot of rubbing with clean very soft rags..you'll be amazed at the end result..a Dremel can spin to fast and eat the paint or heat up the plastic even with its polishing pads..ask me how I know  :banghead:
ok thanks for the heads up ....I'll back away from a dremel, I was thinking of the cleaning up the filler nothing else, maybe precision files?  :thumbsup:
#69
Quote from: Vostoc7 on July 12, 2023, 12:56:53 PM
Strangely the only real way is good old sand paper..wet n dry is the only way to go or sanding pads..well worth hunting some of those down but for simplicity sake I just use sand paper..Aussie made wet n day and multiple grades..everything from 80 to 2000 grit ..it's cheap..lasts and when sanding with water..cuts beautifully without alot of effort.
Hell I use it to polish real cars head lights  :thumbsup:
Files just get clogged up and very quickly .
Files work on epoxy putty but only when it's 100 percent dry which is hard work with sand paper ..a dremel would work here to as the putty will be super hard and a dremel cutting bit will crave the putty and the sanding wheels and disc's will work to but on stuff like Tamiya putty sand paper is ya best bet.
I've got dozens of sheets of sand paper ..I work on real vehicles too so its needed for that aswell 🤘👍
lIke the others.. the solid colour really changes the look and it flows together.
Interesting concept.  :thumbsup:
When it comes to sanding, good old fashioned toothpaste works marvellously in getting nice clear finishes on clear parts etc.
Vulcan7
Quote from: NARSES2 on July 13, 2023, 06:05:21 AMWhen it comes to sanding, good old fashioned toothpaste works marvellously in getting nice clear finishes on clear parts etc.
Great tip, I'll check that out thanks  :thumbsup:
Quote from: Vostoc7 on July 14, 2023, 10:04:43 AM
Canopy cleaning 101..use toothpaste.
That's does work nicely 👌
Quote from: Wardukw on July 14, 2023, 12:51:31 PM
And, it leaves everything minty fresh.
