avatar_buzzbomb
Gas Turbine Chieftain MBT 1/35
Started by buzzbomb, July 07, 2023, 11:57:01 PM
I'm liking it Buzzy ..had a thought about upgrading it a wee bit more with a Commanders Independent Thermal Viewer CITV.. :wacko:
#17
Thanks folks.
Quote from: Wardukw on July 26, 2023, 11:40:54 AMI'm liking it Buzzy ..had a thought about upgrading it a wee bit more with a Commanders Independent Thermal Viewer CITV.. :wacko:
No I don't think so, probably taken it is far as I intend to
Having said that, this is the final tweak, if the Turbine makes the tank faster, then perhaps a track revision might make sense. to include rubber pads.
These are Leopard Tracks and I reckon I will go with them
The start of this train of thought was a pack of Resin Centurion Hush Puppy tracks if had in the tracks drawer.  The combination of not having a spare Centurion drive sprocket (the sprocket teeth layout is a lot narrower) and the fact that they were resin which required a bit of heat and bend business, killed of that plan, but some rubber Leopard tracks... why not.
Buzzy mate the track upgrade is a very nice and smart idea..that tank will be able to move quite a bit quicker now 😀
#20
So that is it for the build part.
Now firmly in procrastination stage... the paint shop
You can always start with the primer & work up from there, BT. ;)
Quote from: Old Wombat on August 01, 2023, 04:45:57 AMYou can always start with the primer & work up from there, BT. ;)
Yup  :thumbsup:  :thumbsup:
That of course raises the question..colours ..what camo to paint it?.
Could just go with British dark green or OD ..then just weather to lighten it up abit.
Quote from: Old Wombat on August 01, 2023, 09:36:21 AMBerlin Brigade! :wacko:
Was thinking that Guy but couldn't remember what it was called  ;D
A different but simple scheme would be either British forces in Aden, or Jordanian.
Steel Penguin
 :thumbsup:  :thumbsup:  :wub:  :thumbsup:  :thumbsup:
Berlin Block gets my vote as well.
