The Bv 148, Dr Vogt's 'conventional' version of the Bv 141 - DONE
Started by PR19_Kit, July 08, 2023, 03:11:24 PM
loupgarou
Quote from: Wardukw on August 11, 2023, 10:56:49 AMThat's the worst part Kit...I haven't had a great time with scribing.
The hardest part is keeping the ruler in place and cutting the panel lines..one way or another I'll find away to do it..my bloody left hand is the problem so I've got to find a way to work with that.
Disclaimer: Something I have read:
Some modellers use old-style Dimo tape (quite thick) It works well also on curved surfaces, but is wasteful of the tape. In a big job, can be costly.
IF you can find the stuff! I've used it before and it's pretty good on quite sharply curved surfaces, and can be re-used a few times too, but it seems to be almost extinct these days.  :banghead:
Well that makes no never mind to me as I've never heard of the stuff 😄
Quote from: Wardukw on August 11, 2023, 02:17:39 PMWell that makes no never mind to me as I've never heard of the stuff 😄
You never had the joy of using a Dymo label maker? :wacko:
DYMO Embossing label maker
Quote from: PR19_Kit on August 11, 2023, 12:31:14 PMIF you can find the stuff! I've used it before and it's pretty good on quite sharply curved surfaces, and can be re-used a few times too, but it seems to be almost extinct these days.  :banghead:
They still make it, and there are knock off versions available from other manufacturers.
DYMO Embossing Labels
Knock-off on Amazon UK
Airmall Dymo Compatible
Quote from: jcf on August 11, 2023, 02:58:28 PM
Oh now I know what you blokes are talking about and I've seen them before but they don't look anything like here that I've seen and nope never used one so no never heard of the tape .
Quote from: Wardukw on August 11, 2023, 06:51:54 PM
It's useful stuff. It stays in a straight line while scribing. I haven't tried it but I bet you could cut a shallow curve and scribe that. Good for repeat scribes.
Quote from: PR19_Kit on August 11, 2023, 10:51:37 AMAnd it also means I ought to re-scribe some of it once the PSR is done too.  :banghead:
Chris's First Rule - Remember you are 72 feet away  :angel:
Quote from: NARSES2 on August 12, 2023, 05:58:35 AM
:thumbsup: Which was why I never rescribed when I was still working in plastic.  But also, probably, an advantage of the kits mastered by the Matchbox ditch digger.
Yes, very true. But that big slab of a wing would look rather strange if it was smooth all over, like a Mosquito's does.
The back story (which is already written....) says it was designed to use as many production Bv 141 parts as possible, just with a different type of rivet, so it'll need SOME panel lines, just not a lot.
frank2056
I happened to be building an old 1/72 F-104 kit (It was a bagged kit without instructions - it had raised panel lines). I was obsessing over what to do with the panel lines. A few days later, I went down to the Chino Planes of fame museum and they had an F-104 out in the bright sunlight. Not only could I not see panel lines (other than control surfaces and the nose cone)from 72 feet away, I had to get within a foot to see them.
I'd agree with your comment about the F-104, but technology had progressed markedly between 1943 and the late 50s.
On that actual web page about the F-104, the heading pic is a Meteor T7 and the panel lines on that are pretty obvious.
I've got the tail assembled now, two Bv 141 tailplanes joined end to end with a couple of modified Bv 141 fins/rudders plonked on each end. I think it looks suitably un-conventional for one of Dr. Vogt's creations.  ;D
And yes, it's mounted on a low pylon because that came off the 141 production line as well.
The all new Rheinmetall-Borsig HL 148V gun turret is all assembled now, complete with guns, and it's had a LOT of filing carried out to match it with the 148's fuselage cross section too.
The little dingus sticking out of the middle of the turret is the 'Hinten Radarwarngerät', an early attempt at seeing the radar from prowling Mosquito intruders.  ;)
And if you believe that, you'll believe anything.  ;D
The Brits had a radar equipped anti-nightfighter turret, the Frazer-Nash FN-121, so why not the Nazzies?
The scanning system had the rather amusing name of Village Inn.
;D
Automatic Gun-Laying Turret
Very similar in purpose, yes, although the 'Village Inn' system looks a lot more practical from the size point of view.
The 'HR gerät' looks like a toy by comparison.
