avatar_frank2056
Project AESOP 1/350
Started by frank2056, July 08, 2023, 07:30:40 PM
frank2056
I like flying saucer designs, so when Takom came out with their 1/350 Haunebu I, II, III kit, I had to have it. I no longer build NAZI crap but since these saucers are all fantasy, I'll make them allied post war designs based on discovered alien artifacts.
There are three saucers in the kit - small, medium and American sized.
Backstory:
In 1947, while surveying locations in Alaska for an early warning radar system, the US Army found the wreck of a uncrewed (unaliened?) alien spacecraft, embedded in a hillside and covered by snow and gravel. While most of the vehicle had been crushed by debris, a rocky overhang protected what was later determined to be the drive unit. Early radiocarbon dating of plant material found around the vehicle indicated that it had been embedded in the hillside for close to 7000 years.
While removing the remains of the vehicle, the cylindrical gravity shielding drive unit - which was mostly undamaged - was seen to levitate slightly when passing a nearby electrical generator. With the hope of using this alien technology, the Defense Department created  Project AESOP - Advanced Extraterrestrial Spacecraft OPerations.
Full reconstruction of the original vehicle was not possible - the shattered crystaline substrates that seemed to control the vehicle could not be reproduced (later studies of the fragments in the late 2040s showed them to be some type of quantum computer), but a partially successful reverse engineering of the drive unit allowed the construction of a small test vehicle in 1950.
Since the science and engineering behind gravity shielding weren't fully understood in the early 1950s, the vehicle had to be circular in shape to allow the reconstructed drive unit's field to lift it from the ground. While strictly an atmospheric design, the saucer showed excellent acceleration and maneuverability. Control in yaw and pitch were done by three dishes pointing inwards under the drive unit. By varying the power, frequency and direction of the microwave emitters at their focus, the drive unit's field could be shaped and modified to allow directional control. It was also discovered that even with the directional controls active - as long as the drive unit was on - the vehicle was nearly invisible on radar.
This is the original design from 1950:
Flight tests showed that the rounded crew compartment might be interfering with the shape and efficiency of the field generated by the drive unit. A truncated crew compartment was added in 1951, and flying from the Muroc/ Edwards Air Force Base, extensive flight tests were completed over the California deserts:
In 1952, George Adamski claimed to have photographed this saucer in flight from Desert Center, California. The US government saw this as an excellent opportunity to hide the project - in plain sight - so they  created the UIO (Useful Idiot Office) for Project AESOP to support and promote UFO conspiracies - they dumber and more outrageous, the better. This cover allowed the design and testing of larger units.
// end of back story
I haven't quite finished this model - I want to knock back some of the grainy paint texture and clean up some of the weathering. The underside looks awful:
The three disks are from a car kit that just happened to fit. I didn't like the three turrets included in the kit, but I may replace these. I used a PE hatch for the crew.
Here's the crew compartment with one crew member:
I'll post the other two as the builds move along.
Interesting. Keep us posted on this one.
We now have to decide if this is a "What if" backstory or clever propaganda ?  ;)
Looking good  :thumbsup:
Quote from: NARSES2 on July 09, 2023, 06:52:16 AMWe now have to decide if this is a "What if" backstory or clever propaganda ?  ;)
Oh I've not had enough coffee this morning to even begin to think about that  ;D
frank2056
If you guys think this "story" is nonsense, then the UIO is doing its job!
I forgot to mention that the white dome in the AESOP I is cut out from a Plink! garbage disposal deodorizer container (in the US, most kitchens have garbage disposal units in one side of the sink. Although no one puts garbage in it...).
The second saucer is coming along. The third saucer in the kit is huge. I think I'll keep that one for a future project.
frank2056
AESOP II is coming along; I may get to putting it together and even laying down a base coat of paint.
I really don't like the cylindrical crew compartment, so I looked for alternatives. Two good ones were a small plastic egg and the internal stopper from a bottle of 3D printer resin. Both are Polyethylene or similar plastic that won't take glue well, so I vacuformed copies.
This is with 0.20" plastic - too thin:
I redid it with 0.40" plastic and it worked much better. I used a dental vacuformer (they're relatively cheap and rugged).
In place, with a small observation window. I have some putty in the gap between the two plastics:
The crews working on the US version called it the "Mansfield" and on the RAF version the "Dors". I don't know why...
Quote from: frank2056 on July 10, 2023, 05:43:06 PM
frank2056
This one is almost done - it needs decals, a figure or two and maybe a base:
It's a pretty big vehicle, when compared to a large truck (from L'Arsenal):
I'm going to skip building the third saucer, which is much larger.
I added PE railings to the boarding ramp instead of the kit railings, which were far too thick. I painted them red, like the handrails on the C-57D from "Forbidden Planet". I also blocked off the ramp well and added a hatch, although it's not visible in any of these pictures:
I added some inks to the clear acrylic. The variations aren't very obvious in these pictures, but they break yo the solid metal finish:
I love it! A great 1950s vision of space travel! You need some aliens with huge clear helmets and big claws!
frank2056
Alien Repo men! "Hello, we're here to reclaim our lost property. We have also been trying to contact you about your flying saucer warranty"
frank2056
Ramp and airlock door:
Part of the crew is taking a group photo (although I noticed that the photographer is aiming off to the side). One of the crew members is holding a "stick" which is just a support that I forgot to take off. I think these are NorthStar 1/350 3D printed sailors:
The photographer is actually a Soviet spy taking photo's of the really secret stuff off to the side, past the truck. ;D  ;)
Quote from: frank2056 on July 18, 2023, 11:47:21 AMAlien Repo men! "Hello, we're here to reclaim our lost property. We have also been trying to contact you about your flying saucer warranty"
 ;D  ;D
The figures give it a nice sense of scale  :thumbsup:
frank2056
I'm finished with this build.
Top view:
The tarmac is a free 1/400 airport tarmac that I printed and glued to a piece of foam. The foam started to warp while I photographed this on the hot patio surface, but has since unwarped.
Both saucers:
I'm going to use the third and much larger saucer (and associated bits) for future projects. The landing gears in particular are nice.
Thanks for following along!
