Main Menu
avatar_mat
Northrop N-102 Fang
Started by mat, July 25, 2023, 03:15:52 AM
mat
In late 1952, Northrop started a design study for a simple, lightweight, supersonic fighter aircraft, the N-102 Fang. The project was an attempt to tackle the growing weight, complexity and cost of fighter aircraft. USAF did in the end chose the Lockheed F-104 as a replacement for the F-100. But Northrop stuck to the idea of a lightweight fighter aircraft and in the following years it developed into the F-5 series.
But what-if the Fang had been the choice of USAF. Then Fang would have been produced in the thousands and have seen service with myriads of air forces.
My build will be a re-engine from four engines to one engine, as the build will be based on the wing (and maybe some other pieces) of a 1/144 Academy B-58A Hustler. This will be supplemented with whatever I can find on my scrapyard.
Quote from: zenrat on July 25, 2023, 04:04:33 AM<popcorn>
Me too, that Fang's an interesting and elegant shape.  :thumbsup:
This im gonna like right room then get go 😁🤙
Fantastic! A very sexy looking aircraft!
You could do one as a developed version with a larger nose for a radar and other bits like what happened to the F-16 and F-18.
I have a small scale Hustler too and this is a great project for it. Another for the to do list.
comrade harps
This is a lot more than a re-engining project. l look forward to seeing it cone together.  :thumbsup:
Whatever.
63cpe
Oh, that's a sexy looking aircraft. I' m following to see how you're going to tackle the fuselage. Obvious choice to use a b-58 wing as it's a good start.
David aka 63CPE
Quote from: PR19_Kit on July 25, 2023, 04:50:29 AM
Ditto - cute li'l thing...
What engine did it have? J79?
mat
Quote from: kerick on July 25, 2023, 11:00:40 PMWhat engine did it have? J79?
You are spot on - A General Electric J79-GE-1 with 9.300 lbs thrust dry - 14.400 lbs thrust with afterburner.
Fuselage?  Ye olde KP Su-25 Frog foot.  Looks to have the same slab sided fuselage and the KP kit has separate engines. Plastic is quite thick IIRC, so that may help.
mat
First step in the build is the conversion of the wing. The trailing edge of the N-102 wing formed a straight line.
Zero-Sen
Can I suggest something along those lines?
Quote from: Zero-Sen on February 11, 2018, 11:16:01 AMSome scale-o-rama with two J79 in a single engine pod, inspired by the B-58 used as a flying testbed for the GE J-93 ...
I wasn't aware of this project, it's a very elegant design  :thumbsup:
