avatar_sandiego89
Rotodyne, Pegasus powered V/STOL support *finished*
Started by sandiego89, August 22, 2023, 03:11:30 PM
Gray primer on.
Detail on the clear resin casted Pegasus came out well! I am happy with it.  Looks much better with primer.
Glad ya primed em Dave cause now I can see the darn things 😆
They are looking pretty sweet too  :thumbsup:
Agreed, the castings appear to have worked out quite well.
On to the exciting stuff as the next steps happen  :thumbsup:
That's one HECK of an intake, but then a Pegasus is a hungry beast after all. They look even better now they're painted up.  :thumbsup:
Quote from: PR19_Kit on August 27, 2023, 02:48:31 AMThat's one HECK of an intake, but then a Pegasus is a hungry beast after all. They look even better now they're painted up.  :thumbsup:
Well a lot of what went in there got blown straight out of the front nozzles.
I presume Dave, that the 'dynes tip nozzles are fed from the Pegasuses (Pegasi?) low pressure compressors?
Paint and engine work.
The Pegasus engines are a tad bit beefier than the Elands!
very rough placement mock up
decided to switch to a Hasegawa Gr.1/AV-8A as a companion
Quote from: zenrat on August 27, 2023, 05:19:54 AMWell a lot of what went in there got blown straight out of the front nozzles.
Yes, diverted from the cold compressor stage.
paint and assembly continues
The hinges are fiddly.
I reinforced the hinges
Carpet monster got the main rotor shaft.  scratching one up with three diameters of brass tubing.
Put some extra clear sheet to keep the windows in place.
Nice stuff Dave and it's good the carpet monster got the plastic shaft..brass is far stronger.
Fact I prefer to replace all plastic rotor head shafts on my choppers cause I'm guaranteed to break em  ;D
A friend of mine used to leave the rotor head unglued and removeable from the shaft, for transport/storage - but I guess you've already thought of that, so as you were and carry on...
Quote from: McColm on September 04, 2023, 01:13:30 AMHave you thought about the landing gear?
Yes, the gear should be straight from the kit.  The exhaust nozzles from the Pegasus will go around ea h side of main landing gear (much like the Harrier)
