Main Menu
Supermarine Speagle - REALLY done!
Started by PR19_Kit, August 31, 2023, 08:54:55 AM
Vulcan7
Great idea, you can't beat a Spit build ;D  :mellow:  :mellow:  :thumbsup:  :thumbsup:
A slicker Spit... what is not to like
Quote from: jcf on September 01, 2023, 02:24:23 PMAlso, it's far too American of a solution.  :angel:
Exactly..............  ;D
All sorts of other aeroplanes were used as engine test beds, during WWII and afterwards, but that never seemed to happen to a Spitfire, they always had Merlins or Griffons. I thought I'd change history a bit.  ;)
Quote from: kerick on September 01, 2023, 02:17:09 PMOh just put a triangular piece in front of the tail like the Mustang.
That just won't do, dear boy, it'd be much too angular and wouldn't flow smoothly into the rounded fin.
They did that with the prototype MkV Tempest and it's... not the best look... I've heard the term 'Fugly' used (in my head, at least!  ;) )
Quote from: buzzbomb on September 01, 2023, 03:41:11 PMA slicker Spit... what is not to like
Absoloutley nothing to hate about that ..the super slick Spit would look amazing .
Quote from: Rick Lowe on September 01, 2023, 04:11:12 PM
Got a 1/48 Spit fin?
Just take a piece of aluminum and fold it in half and you're done!
Having worked out how long the prop-spinner assembly will be, in order to line up properly, I think this Spit will need a LOT of ballast in the tail to keep its CG in the proper place!
It's not looking too bad though.
How difficult would it be to lengthen the tail a little?
Quote from: kerick on September 02, 2023, 08:17:42 AMHow difficult would it be to lengthen the tail a little?
Not easy, and it would lose the inherent 'Spitfire-ness'of the shape. But I could extend the fin rearwards, as well as adding the dorsal fin. That might do it.
Luckily ballast weights are invisible in WhiffWorld.  ;D
Quote from: PR19_Kit on September 02, 2023, 09:27:36 AM
Of course one could take the Kurt Tank approach, slice off the tail, throw in a biscuit tin, and when that isn't enough add some planks to the vertical fin.
;D :wacko:
Make the vertical taller as well as broader?
Hope the flight manual told the pilot to go easy on the brakes!
nice!
perttime
#29
Quote from: jcf on September 02, 2023, 10:08:28 AMMake the vertical taller as well as broader?
Tricky with the rounded shapes?
I suppose one could add material between fin and rudder to extend back and up - but then the rudder itself would need extending. It is pretty vertical at tailplane level.
Oh.... Landing gear.
Looks like 391, like Spiteful, was to have main wheels fold inwards  :mellow:  :wacko:
