avatar_Wardukw
RAAF SAAB AJ37 Viggen
Started by Wardukw, October 13, 2023, 03:30:07 PM
Quote from: PR19_Kit on October 21, 2023, 02:24:37 PMSome one does a masking set for the SwAF 'Fields and Meadows' schemes, but I don't know if it's available for 1/48 as well.
Wouldn't surprise me Kit if there's not but that would make life much easier.
When I painted this...
nattfjÀril 8 by Fred Maillardet, on Flickr
...I primed it, drew the pattern in pencil, labelled each block, and then brush painted the splinters - like a paint by numbers, no masking needed.  Took some concentration but it'd be easier in 1/48 as its bigger.
What I do is just free hand the design..basically what looks simple but effective and similarish.
So far all seems to be going well..I hope .
Camo Black; Camo Green; Camo Brown; Pilbara Brown
If you aren't using a specific AusCam set then a slightly reddish Dark Earth should do for the Pilbara.
I used them on this.  No masking, sprayed freehand.
AAVA-7A1 - 10 by Fred Maillardet, on Flickr
I used the first 3 (also free-hand) on the Landy;
Pre-weathering        Post-weathering
I'm gonna use Tamiya XF-52 flat earth  as the 4th colour.
The good thing is not much of it is used compared to the other 3.
Should look OK..your guys eyes will see it better than me  :thumbsup:
By the way guys..all those builds look amazing  ;D
Well she's painted lads ...waiting  for the underside to be bone dry and then I can unmask it..ive already unmarked a small bit and it don't look to bad at the mo...I'll be very interested in your guys opinions. 😉
Everything goes well pics will follow later today.
Pics will be up tomorrow guys ..I  took 2 pics and then the batteries crapped out in my camera .
I'll get more tomorrow..take more pics and then it will stay on long enough so I can upload them to my computer.
First impressions from me..it's looking quite cool 😎
Beermonster58
Special Hobby produce a set of 1/72 masks and, a company called D N Models produces a 1/48 set
Well i got new batteries for my camera lads so here ya go  ,,,an Aussie Viggen .
DSCF4406 by Phill Harrison, on Flickr
DSCF4407 by Phill Harrison, on Flickr
DSCF4408 by Phill Harrison, on Flickr
DSCF4409 by Phill Harrison, on Flickr
Next will be pics of the cockpit and pretty much everything else...which i havent done much with to be honest  ;D
Beermonster58
That's how it SHOULD look! :thumbsup: .
As a principle, I don't do boring, grey jets. I always look on a boring, grey finish as a challenge to overcome.  I might use larger ,individual coloured areas to ease masking a bit or, maybe solid coloured decal sheet.  However, as I'm going to build three Viggens in three separate roles with schemes to match, I might just end up using the Special Hobby 1/72 masks. Nice to see you've installed the inboard wing pylons aft of the wheels. These were very rarely seen .
Mate when you first told me of those within 10 minutes I was looking for some rail  ;D
Open door bud... quite happy to step thru 😊😊
